Question about Linksys (WRT54GC) Router
Installing i have an ibook g4 & cant find aprogram to read the set up wizrd for the linksy router. i tried using the application acrobat but the dialog box said resource mismatch so i ejected the installation disc & re tried the installation but acrobat mis match keeps coming up. how can iget rid of acrobat & start again?
  • sarita allison Jan 18, 2007
    idid send a rating: It was good it helped me alot!
    hank you very much!
    scritz
    President:
  • 2,961 Answers
Look in instructions for the address of your router( eg 192.168.1.2) to type in your internet browser and access the router settings.
Posted on Jan 16, 2007
I can not install viber apple ibook g4.when ever i try to down load i am told the application viber can not supported by this architecture
Hi Christy,
Viber appears to work only with OSx 10.7 and up, which is not supported on an iBook.
When they say "viber can not supported by this architecture", they're referring to the iBook not having an Intel processor like the MacBooks do.
Hope this helps!
Aug 19, 2013 | Apple Ibook G4 14", 1.33...
Looking for instructions on how to install blue tooth card into e-mac g4
Here ya go.
should give you what you need
[PDF] iBook G4 (Late 2004) Getting Started (Manual) File Format: PDF/Adobe Acrobat - Quick View
install one, see “Installing an AirPort Extreme Card or Additional Memory” on page 51. ... You can also find information on the Apple Bluetooth ...
manuals.info.apple.com/en/ibookg4gettingstarted.pdf - Similar
Jul 12, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
I have an ibook G4. The display is hard to read and the graphics are terrible. I've tried adjusting the resolution and display with no improvement. It's hard to read. Help please!
Try reseting the PMU and Pram,also check the d.Also check the system with saperate OS installed HDd.It will work fine.Format the HDD and the issue gets solved
Apr 07, 2010 | Apple iBook G4 Mac Notebook
IBook will not connect to Linksys WRT54G router
you can reset your linksys router on factory mode and after that you can try to connect your iBook. if the connection happen then you can again re configure your router as per your require security policy.
Mar 30, 2010 | Linksys Wireless-G Broadband Router
While is was searching on the internet my iBook G4 locked up. I tried to reboot and it locked up again. I tried to reinstall OSX but during the install it locked up. I replaced the memory and hard drive...
Dude, if you have all the current updates for your OS and applications, then you got a logic board issue. Especially if you you keep seeing the spinning beach ball of death or the dreaded white screen of death.
The iBook G4 is the poster child for logic board defects, because it has to do with the way the circuit boards were flowed.  Apple won't fix this for the iBook G4.  You got to do a big class action lawsuit like they did with the iBook G3 before they will replace the logic board.
Best bet is to sell this thing on e-bay as a non-working unit and get you a better laptop.
Oct 18, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My iBook wont connect to my Linksys wireless G router
try removing the passkey and security on the linksys
then enable reverse authenication, by allowing only specific MAC addresses to access the router. ( MAC FILTERING ) ONLY ALLOW
then add the MAC addresses of your IBOOK and what ever else you have..
simple and secure :)
Aug 21, 2009 | Linksys Wireless-G Broadband Router
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
Connecting ibook to linksys
- If your router has an encryption, make sure you were using the WPA.
Mar 17, 2009 | Linksys Wireless-G Broadband Router
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
Open Questions:
Linksys (WRT54GC) Router Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
