First started dragging at start then just got worse. Looking for trouble shooting instructions in proper order
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
SOURCE: trying to rewire my ingersoll
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Just took off belt cover, can easily turn by hand. Belt was loose and looks like too much load has worn it down. Tightened belt and started, motor is very strong, but something is too hard to turn...belt tries to slip and pulls motor down some. Any ideas?
