Question about Refrigerators
Ice maker does not work
Red light blinks twice then stops.
  • 120 Answers
The lighs are normal if you have no ice then is something else ok remove the cover infron of the ice maker there you should see the the ejector it looks like spikes or forks ok they should be facing you if they are facing down into the mold then you have a broken module in ice maker now there isa fill tube on your right that fills the mold with water squeeze it is hard or soft if hard then is frozen keep it from filling the mold de ice it with hair dryer or unplug unit for a day or so . next if spikes are facing you and there is no ice then you have to trouble shoot the water valve at the back of unit there are 2 selenoid 1 for dispencer and 1 for ice maker locate the one for the ice maker and apply 12o volt directly into selenoid if you get no water replace it. if you get water repl optic board that is the red lights ok
Posted on Nov 28, 2008
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Seee note on ice maker stopped working, blinking red light
heatman101
rtwywy
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
