Question about Fantom Vacums FM744H Vacuum
I want to know how remove the filter to clean or replace on my fm744h fantom vacuum
    Problem Solver:
  • 5 Answers
The hepta filter has a place on each side to push in.The top
comes off and the filter is inside.The new one is about 24.00.
Remember to clean the dust filter .This is located in a chamber
below the cannister . Remove the cannister and there is a grey plastic tab,it will comes up and dust filter is right there-pinch
it and it will peal out.It can be hand washed and air dried.
Parts at
Posted on May 26, 2009
I have a Fantom Thunder TH469KA and it shuts off after 5-10 min of running How do I fix this?
on all vacuum cleaners the air flow cools the motor. If the filter is sufficiently clogged there would not have enough air flow to cool the motor and trips out from over heat. Clean out the filter thoroughly and try again.
Jan 01, 2015 | Fantom Vacums Vacuums
Hi, I am looking for a replacement filter? any chance you can help me?
It would help to know your location so I can provide details a local supplier, however you can order a complete set of new filters from here:
These cost $9.99 + shipping and are Genuine Fantom replacement parts.
Hope this helps.
Oct 21, 2010 | Fantom Vacums FS801 Vacuum
Dirty filter
Never mind I found someone that didn't want to charge me for telling me how to remove filter.YOU WERE NO HELP! Thanks
Aug 22, 2009 | Vacuums
My Fantom Cyclone keeps turning off after 10 minutes of use. I will then let it sit for a few hours and then I can use it again for 10 mintues.
You may need to clean some internal filters. The one above the motor, just below the dust cup and maybe the exhaust filter
Jun 29, 2009 | Fantom Vacums XT450K Upright Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Change my belt on a fantom vacuum model number is f1420gf
Generic problem for all Vacuums
Change my belt on a
Posted by sylvester021 on Jul 10, 2008
Change my belt on a Fantom vacuum model number is f1420gf
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt change on the Fantom is to remove the bottom plate by undoing the screws, clips or levers, then cut off the old belt, remove the brushroll on the pulley side and place the new belt on the pulley side and replace the brushroll. Then use a belt puller or screwdriver with a hook on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line. The replace the bottom plate and you should be fine. The recommended belt change on a vacuum with a flat belt is every 4 to 6 months for the best cleaning and always use the genuine belts for the Fantom. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Vacuums Logo
71 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
