Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
French door refrig..right door pops open when left door is closed
I have an Amana French door refrigerator with freezer on bottom...Model # AFB2534DEW. I have notice lately that when I close the left door last, it causes the right door to open, and it doesn't shut all the way, allowing cold air to escape. What is the problem, and what do I need to do to fix it...thank you
  • Anonymous Mar 10, 2009
    I have a Kenmore which is really a Amana. A year right after warranty expires the right door pops open when I close the left door and doesn't automatically reclose.
    After doing some research I found door alignment screws at the bottom of the frig and realigned the left door and the problem got fixed.
    Problem Solver:
  • 4 Answers
Remove the door and check the closer inside the door @ the bottom . it is a cam that helps close the door and it is probably broken part # 67002732. this was the problem with my maytag fridge-- 3 visits from A& E could not solve the problem. hope this helps
Posted on Aug 22, 2009
  • dangoodridge Aug 22, 2009
    Just a further clarification-- part # 67002732 is the female portion of the door closer and is inside the bottom of the door- #67003638 is the male portion of the closer and it sits on the bottom hinge
    President:
  • Amana Master
  • 2,651 Answers
I would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Posted on Nov 30, 2008
Freezer freezes but refridegator is warm on amana french door refrigerator.
it could be a defective damper vent door,( frozen shut from condensation) between the freezer and refrigerator,the motor that opens and closes this door,or a thermistor in the refrigerator that signals the control board in the rear of the unit to operate the damper vent door motor to open and close this door
Jul 28, 2010 | Amana AFD2535DES French Door Refrigerator
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refrigerator door not closing all the way
the pressure inside the box is pussing the other door open and what you need to do is tilt your refrig back until the door will close by itself and that will be as far as you need to go back with it ,,,, it's normal for it to happen and a frig should always have a little tilt / larryyb
Nov 28, 2008 | Refrigerators
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
589 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
