Question about Epson Perfection 4990 Flatbed Scanner
Film option is ghosted
I have an Epson 4990 scanner. I can't get off document scan. I tried re-installing software but nothing seems to have changed. It worked very well in the past. Steve
  • 1 more comment
  • karagandinka Nov 11, 2007
    I HAVE THE SAME PROBLEM! IT"S URGENT FOR THE SCANNER TO WORK and IT DOESN"T
  • Anonymous Jul 31, 2008
    i have the same problem>>> just installed it but i can't click on the film option
    did you manage to resolve the problem in the end???
    any help????
  • Anonymous Mar 06, 2009
    This fix didn't work for me.
    Genius:
  • 1,447 Answers
Try to reseat (unplug and replug the TPU cable at the back of scanner, and open epson scan go to professional mode and click on configuration button, go to OTHER tab and press reset all then restart computer and try if film is an option to select.
Posted on Apr 03, 2008
SOURCE:
When I scan film either color or B&W I get a faint grid pattern on the scanned image.
you need to change a setting in the software called "descreen."
if you enable it, it will eliminate that effect.
here is some info about that:
http://www.scantips.com/basics06.html
Feb 18, 2009 | Epson Perfection 4990 Flatbed Scanner
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
Need a document feeder for 4990 scanner
I don't believe it is possible to add a paper feed to this scanner. The only hopper fed scanner of which I'm aware is the Kodak s1220.
Jeff Underwood 1Scan.co.uk
Feb 13, 2009 | Epson Perfection 4990 Flatbed Scanner
Epson software update for Leopard
Hi-
Is this the one that you tried installing? when you opened the file do you have a sub installer folder as well? if you have sub uinstaller folder, open it up and install everything as well then try running the epson scan. keep me posted for any progress, thanks!
TWAIN Driver and EPSON Scan Utility v3.03A
Intel-based Macs with OS X (v10.5 - 10.5.x) compatible, PowerPC Macs with OS X (v10.5 - 10.5.x) compatible, Intel-based Macs with OS X (v10.4.4 - 10.4.x), PowerPC Macs with OS X (v10.2.8 - 10.4.x)
epson12093.dmg - 11.9MB - posted on 12/01/06
Jul 14, 2008 | Epson Perfection 4990 Flatbed Scanner
Misalignment of scann after area selected
the 4990 often failed to detect automatically the film. Go manual, take the film zone, don't forget to specify it in the driver (the focus depends on it), and crop manually the picture. The result is perfect because it's yours. In many times, if the result is important to you, forget the automatisms.
Feb 24, 2008 | Epson Perfection 4990 Flatbed Scanner
4990 scanner
Nothing is wrong if your scan turns out good
Jan 22, 2008 | Epson Perfection 4990 Flatbed Scanner
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Microsft Vista doesn't support 4990 negaives scanning
try using a third party scanning solution EPSON is known not to keep up their drivers so many third party solutions have popped up. I like one called vuescan http://www.hamrick.com/ it works for MAC and PC and is not very expensive
Jul 03, 2007 | Epson Perfection 4990 Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection 4990 Flatbed Scanner Logo
339 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
