Question about Viking VGSC306-4B Gas Kitchen Range
Need to know ohm reading
I have a norton 501a ignitor and i need to know the ohm reading
  • scooby8714 Nov 29, 2008
    your the best!!
  • 1,543 Answers
When room temp, you'll see about 80 ohms. As it heats the resistance goes up, and thus the amperage draw goes up, which is the critical component to release of gas and thus ignition. The ignitor needs to reach 3.2 to 3.6 amps before the gas safety valve will open and release the gas for ignition. Old ignitors get weak and even if they still glow they may not draw enough amperage to allow the oven to work. Also, low voltage will result in lower amperage draw and possible ignition problems.
Posted on Nov 28, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 29, 2008
    Thanks for the comment. A FixYa rating would be appreciated. Thanks.
Hello, i have a kenmore 80 series gas dryer(110.74842400). it will start, heat up three times, then wont ignitor glows and just shuts off for the rest of the cycle. i was pretty sure it was the coil
Hello Brian;
My name is Peter. I am a retired field service appliance technician.
Recently, I worked on a LG gas dryer. I Ohm the thermostat and found that to be bad, but when I Ohm the ignitor I got a reading of 135 Ohms. I replaced the ignitor. The new ignitor Ohm reading was 167. In other words, the ignator did glow red, but did not have the power to open the gas valve.
Although, you checked the electrical continuity of the gas valve, that does not check the mechanical issues. Sometimes the spool in the valve sticks or does not fully open. You need to hit it with a hammer and turn the dryer on. Repeat this about 8 times.
Make sure your hot air distribution manifold is not plugged up. This too will shut your unit down.
Nov 06, 2014 | Dryers
Ignitor isnt working
The oven ignitor should have a resistance reading of about 3.2 to 3.6 ohms. If the readings are out of this specification or show open replace the ignitor. measure the resistance of the oven valve. The gas valve should have about 1.5 ohms of resistance. If the gas valve is OK, the control board is suspect. The ignitor needs 120vac to work.
Apr 07, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
My dryer doesn't always ignite. I took kt apart and the ignitor only glows about one out of every 2 times I start it. The ohm meter reads 76.6 ohms.
The best way to check that is by checking for power to ignitor. Place your meter leads into the plug from the wire harness,not the ignitor,but what it plugs into and start dryer it should have 120vac , if it does the ignitor is bad,typical ohms on a ignotor is anywhere between 50-400 ohms,if no power to ignitor next check flame sensor for ZERO ohms BE SURE TO UNPLUG DRYER FIRST,when removing wires to it you WILL be shocked if the dryer is plugged in,the flame sensor is the black part attached to the turner tube, if OL or anymore than 5 ohms its bad
Hope this helps
Gene
Aug 02, 2011 | Dryers
How do I tell if the thermostat is bad or the ignitor is bad for my GE oven JGBS07 EV1WW
The way to tell for sure is to take an ohm reading on both and a current reading on the ignitor. The thermostat should read 0 ohms when calling for heat. The ignitor should read some resistance but not an open circuit. The current draw through the ignitor should be about 3.2 Amps, any less means it is too weak to open the gas valve.
If you do not have meters try these checks.
If the ignitor glows at all then the thermostat is good. If the ignitor does not glow at all it could be either the thermostat or the ignitor,
If you can see the ignitor close up sometimes you can see a white spot on it or a crack, this means the ignitor is bad.
If you have to guess which one the smart money is on the ignitor being bad
May 10, 2010 | GE Kitchen Ranges
I have a Bosch gas range Model: HGS346UC 0/1.
If the cooker has a digital clock it needs to be reset to manual or until 00.00 appears on display . To do this hold " - " button until the 00.00 is displayed .
Then press and hold the "+" and "-" buttons in both together at the same time until all settings have been cancelled . Try the oven now and it should come on.
Mar 26, 2010 | Bosch HGS 255 Gas Kitchen Range
Motor will turn on and run, but on heat... The timer will not time out, the glog igniter does not glow.
it sounds like the hot surface ignitor is bad. if you have an ohm meter check across the leads going to the ignitor, it should read a resistance of some value, if it reads "o" the ignitor is open meaning there is a crack in the ignitor. you can remove it and visually check it for cracks in the coil, sometime they are hard to see so look very closely ,even under a magnifier glass.
a good ignitor should read 10 ohms if it reads higher it may still work for awhile but is definitly on its way to failing soon.
Dec 28, 2009 | Roper Dryers
Will not ignite. NO HEAT
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the unit the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
Now, if the ignitor passes the inspection, and test, this will lead to a failed set of gas valve coils.
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Nov 02, 2009 | GE Dryers
GE gas drier dhdsr46ge1ww will not heat up
Aug 24, 2009 | Dryers
WHIRLPOOL DRYER 5-6 YRS OLD
Navy 2nd Class Diver 1969-73
The Ignitor is fine? So, it heats on some settings and not others?
The OHM Meter test for continuity.
Some parts give a reading of a certain amount of OHM's but, most the time all you need to know is if you get any reading on the meter at all. This shows there is no break inside the part. You can check the ignitor this way also the solenoids on the gas valve.
If the ignitor glows red then shuts off and does not ignite the gas, this could be the sensor or the solenoids. The sensor located close to the ignitor, will detect the glow from the ignitor and send power to the solenoids on the gas valve.
Jan 26, 2009 | Dryers
Viking VGSC306-4B Gas Kitchen Range Logo
469 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
