Washer won't start to cycle after initial filling
After filling with water for the first wash cycle, the machine just stops and won't go into the cycle. Model # 110.24622300
  • Anonymous Jan 16, 2009
    We have the same problem! And the washer is only 3 years old. Annoying!
    Sergeant:
    Champion:
  • 311 Answers
Did you check if lid switch is closing? You'll need a meter to do it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Machine won;t start cycle
Nigel,
Does the washer start at all? If it doesn't start at all it is probably the timer. This can also cause the washer to stop in mid-cycle. If it fills up with water and then stops it is most likely the lid switch.
Oct 13, 2014 | LG Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
