Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Display dies, although phone still functional
By dai5 on Jan 15, 2007
I'm having a problem with my Razr V3.The display is going completely dark,although the phone seems to be working fine otherwise (ie I'm able to make/receive calls, voice dial is working...) I had this happen 2 or 3 times, and each time the display came back after 5-10 minutes of tweaking with the phone (removing the battery, plugging the power cord...) I have tried to detect some kind of pattern, but haven't been able to. Last time around, with the display working, I left the phone connected to the power cord for 5-6 hours, and the display was fine. 2-3 minutes after removing the power cord, the display died again...
Has anyone had a similar problem? Any thoughts / ideas?...
Thanks a lot!
-Dan
Comments:
Feb 06, 2007
- Hi all,
I posted the original problem (back in Jan). Somehow the LCD started working again (and hasn't failed since). I think it was a combination of the battery connectors being not so clean, the flex connector to the LCD being a bit loose and (maybe?) the battery dying. I haven't bought a new battery (this one lasts ~3 days without too much talking), but I plan to do so...
For those of any still having problems, if you're courageous enough, there is a fairly good repair manual for the RazR at
www.lovehopefaith.com/V3.files/V3-repair.pdf
Cheers,
-D
P.S. My next phone will probably be a Nokia...
Best Solution
posted on May 15, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi
The thing with the battery it really worked .so if you have problems with the display just change the battery and your black dead display will turn in a nice working one .you should try it is easy and with results.good luck!
cristina
Solution #2
posted on Feb 12, 2007
Very Helpful)
El Rudo
Rank: Apprentice
Rating: 95%, 15 votes
My razr V3 dropped from an astonishing 40cm to the floor, after that both screens stopped working. I opened the screen by removing the four tiny screws in each corner (t5 screwdriver which I didn't have but the smallest of my miniature screwdriver set just fitted), and popping it up carefully.
There a two flatcables, one with a silvery color and a connector with a black piece of foam on it. I think it's the screen signal carrying cable. I removed it and put it back in place, pushing it firmly. After that the screens worked again.
10 minutes of work and a great deal of satisfaction.
Further, the phone stinks.
regards, El Rudo
Comments:
Feb 12, 2007
- Oh I forgot to mention, if you think you have the loose connector like I had, you might try pushing firmly on the top right corner above the small screen, just a bit down left of the word VGA, to squeeze the connector back into place. Saves you opening up the thang.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Feb 06, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Buy A New Battery!!!
Solution #4
posted on Feb 10, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my phone has just died today after 12 months of hassle free use. the display on the inside and outside doesn't show at all, but i can still make and recieve calls and can get blue tooth to sync by guessing at the correct sequence of numbers. i'm plugging it in tonight, i hope it works....
Solution #5
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I happen to Work for a cell Phone accessories store and the number one phone I get in there is the razor. I have fixed many of them I will Take some pictures on basic fixes for it but if your LCD screens aren't working properly and everything seems connected you just have to replace either the screen or the Razor and honestly get something else. This has to be THE BIGGES PIECE OF CRAP PHONE EVER MADE. Which is wierd cause I love my V195.
Solution #6
posted on Jan 17, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
that happened to my new razr I got for christmas, and I can't figure it out either. But only the screen on the front stopped working, the camera even still works when it's closed. I don't know how to fix it.
Solution #7
Helpful)
RZRsucks
Rank: Wiz  Motorola Expert
Rating: 81%, 224 votes
the above that one is me. If anyone does happen to know how to fix a cell phone LCD screen PLEASE let me know I would love to learn
Was this helpful?
Yes
No
Solution #8
posted on Jan 15, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
mine did that untill i puuged it in to the comp and got the updates
Solution #9
posted on Dec 11, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Motorola produces junk... Made in China... I've been through two Razr phones in less than a year with displays that went bad. I don't think firing their CEO is good enough. Carl Icahn is right - break it into pieces. What a worthless company!
Solution #10
posted on Aug 12, 2007
Not Rated)
Gradey
Rank: Apprentice
Rating: 0%, 0 votes
Solution #5 worked for me... My phone fell about 1 foot and the screen stopped working. I used T-5 to take off the screen cover and sure enough the flat cable was disconnected. I just reattached it and it worked fine. Took all of 5 minutes while wathcing the Cardinals whoop up on the Dodgers..haha
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
i cant format my Motorola v3 does any one know the code ?
Answer
I have a Motorola RAZR v3m, and whenever it is on from anywhere between 2 and 5 minutes, the screen... (More)
Answer
I can't download picture my grandson sent me. Get error message that says cannot download at this... (More)
Answer
I have received photos via text and it says I can't download, how do I download?
Answer
I have a sprint lg rumor and need to know how to down load my photos from this cell phone to my... (More)
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
