Question about KitchenAid KGSA906PSS Gas Kitchen Range
KGSA906PSS Kitchenaid slide in gas range. I just used the quick self clean and the display went black and will not come back on and the door is locked.
The thermal switch was bad. I removed the sheet metal back from the oven and there is a small round part with two wires one on each side. You replace it and bingo the door will open and display will come back on. If you do not have he part you can touch the two wire together and the stove will unlock.
Posted on Nov 29, 2008
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
I have a kitcheaid gas range. just used the quick, self-cleaning cycle/2 hrs. 30 mins./went out came back no display and door will not open/
The temperature cut-out thermostat at the back of the oven has failed. You will need to pull the oven out and remove the back panel. Thermostat should be at the top in the middle. Once replaced oven will be back to normal.
Feb 26, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Gas Self Cleaning Oven: When we tried to use the "self cleaning function" of our oven a "F5 E1" code was displayed. According to KitcheAid this indicates a "Latch System...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Did a self clean now display will not come back on and oven wont open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 12, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Dec 23, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Does Kitchenaid have a fix for this problem? Who do I contact? "After starting the Self Cleaning Mode the Display went blank and the Oven Door stayed locked. The Burner Igniters still work"
the hi-limit thermostat has been tripped. it needs to be replaced and also make sure that the cooling fan is working ok. thermostat is located behind the back panel. looks like a disk the size of a quarter with two wires on it
Nov 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaid KGSA906PSS gas slide in
GO TO THE WEBSITE TO GET THE PROPER
INSTRUCTIONS FOR YOUR UNIT AND WHAT
CLEANERS CAN BE USED FOR YOUR UNIT.
Mar 07, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Self Clean
This problem is well documented on the net and a common problem with running self clean on these ranges. There is a thermal fuse on the back of the oven box (under the outer sheetmetal skin.) It overheats in self clean mode and shuts off gas and power to the oven/display (like it's designed to do in a fire.). IT's a $40 part and not hard to do yourself. All you need is a screwdriver to remove the sheetmetal and part. The replacement part # # is 8300802.
Just fixed mine this week..
hth
Jan 28, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Jul 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
318 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
