Question about HP Media Center m7060n PC Desktop
Hp Mecia Center m7060n fan failed, new fan not detected
My pc crashed a long time ago (probably two/three years ago) with a fan problem. It would always read upon startup system fan failure, please service pc to prevent damage. I just pulled it out of the closet and put a new fan in it. The new fan isn't detecting and the error message still appears at start up. I know I somehow need to detect the fan but I don't know how to do that. Please let me know if you can help!
  • HP Master
  • 2,449 Answers
The fan must be the correct fan
i guess you meant the CPU fan, ? desktops can have 2 or 3 fans.
the fan has 3 wires, in many cases, the 3rd wire is a RPM tachometer that if not correct the PC can not read RPM
if RPM reads 0 the PC will be very upset. and do that.
my guess you bought the wrong fan, and is super easy to do
giving the many fans
on some PCs the BIOS monitors the fan RPM and heat sink temperatures, or both, and tells yous fan bad for either failing
on my PC here, now, I can go in to bios and see both live sensors
RPM and Temperature. this allows for easier diagnosis
i dont think your PC has that page in BIOS to do monitors for trouble shooting, in fact mine has 3 fans all 3 are monitored, now.
high end PC .
this older desktop , only the m7200 pages are there. at hp.
so cant look at the fan nor BIOS.
i use a windows program that lets me watch the fan speeds
and all CPU and GPU core temperatures. (ask) its free.
the troubleshooting guide at HP stops short at this problem
says get it fixed. so you want to fix it your self sure.
so talk to one of the top, CPU/HEATSINK/FAN makers
and buy this from them.
if the fan spins fast and RPM is 0 wrong fant
if the fan spins fast and RPM is ok, then the BIOS dont like the CPU temperature... this has 3 causes.
fan dead. or slow. or wrong fan installed
heat sink fins packed in lint as all do ever year.
heat sink thermal bond compound failure, common.
Posted on Jul 18, 2017
4 Suggested Answers
siawolf
  • 749 Answers
SOURCE: HP D530 SFF CHASIS FAN NOT DETECTED
Should be an alarm setting, usually in the bios, for both chassis intrution and fan and cpu warnings. disable it and no error message.
Most likely the fan power is connected to the wrong fan port on the motherboard itself and placing it on the correct port will fix the issue.
Posted on Mar 17, 2009
  • 189 Answers
SOURCE: Desktop PC system fan failed error
hello.. this means that the fan which cools your pc is not working, get a new fan for your mode and fit yourself if possible or go to computer technician.
do not keep it using as your pc may crash.
its very important to keep the cpu cool to keep computer working. hope this help.
Must rate me.....
Thanks
Posted on Mar 25, 2009
  • 79 Answers
SOURCE: I have an HP Pavilion
This is caused due to wire signals that are sent from the fan to the motherboard.
Open your system case and make sure the fan is running. If it is running then make sure the cable terminating on the motherboard is properly inserted. You can take it out and re-insert.
If issue persists, then you may have to change the whole fan or disable the warning option in BIOS which can be dangerous.
Posted on Mar 14, 2011
I have an HP m7060n with no drivers. It has Windows 7 on it what drivers do I need?
Hi drafter678...
Bad News....Sorry I could not get your drivers for you.
You failed to give me the complete information that I needed to find your drivers..
I needed to know if the system was 32 or 64 bit Windows 7.
Good News...Go to this website and plug in your information and download the drivers you need for FREE.
Update all your drivers
Please take time to rate me
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&os=228&product=459895
Sep 05, 2011 | HP Media Center m7060n PC Desktop
Media Center m7060n PC Desktop: My m7060n Tower turns on, but the key board blinks...
It sounds like you have a board that is not booting at all. Remove everything from the board except the system RAM and CPU and switch it on. If it boots now, shut it down and then replace each individual item one at a time, booting the machine after each item is refitted/connected until you fit something that prevents the machine from booting. Pay special attention to system RAM sticks by removing them/it and refitting it as bad connections in the RAM socket can also cause a boot failure but removing and refitting the sticks usually cures this issue.
May 18, 2010 | HP Media Center m7060n PC Desktop
Start up problem
I've checked your media center model on the net and it appears to be a known BIOS problem. Keep in mind that this is most likely video card or motherboard failure. But we can try resetting it Try booting into the BIOS using the F10 key and then pressing F12 and pressing y. The system should reboot with the default BIOS settings. If there is any change you likely have a good chance at fixing it. Please post your results.
Jun 15, 2008 | HP Media Center m7060n PC Desktop
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
HP Media Center Desktop w/XP
Why would you want to connect to Windows? Yecch. Go to OSNews.com and check around for an interesting OS and filesystem combination.
Still, I'd chalk it up to your having plugged another bootable volume into the machine (e.g. a CD ROM) or otherwise changing the setup from what you brought to GeekSquad. Honestly, you've described the problem circumstances quite poorly. Does it not beep before booting -any- OS?
May 09, 2008 | HP Media Center m7060n PC Desktop
HP dvd rom disabled
if you can open your desktop..try to replace the ide cable of the DVD/Cdrom it might be deffective.before you open your pc just make sure that the power is off.after changing the ide cable of your dvd the system will automatically detect your drive.if you got same problem again try to consult your hardware vendor to claim your warranty parts and service.good luck
Dec 03, 2007 | HP Media Center m7060n PC Desktop
HP Media Center m7060n PC Desktop Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
