My labtop won't turn on.It would turn on for 6 seconds and then turn off and start over again and keep going on and off.
  • 60 Answers
Hi purchased a can of air and give the machine a good clean, it might be the fan which not woring right please try all the above  cheers
Posted on Dec 05, 2008
Why won 't descaling process begin?
everything what you have to do is to turn hot water to start,then after 10-15 seconds stop machine and turn it off. Wait about 10 minutes and rinse rest of descaling agent.Then fill the watertank with fresh water and rinse again trought hot water. When the water finish your machine is descaled.Then press hot water/steam button for 5-6 seconds and light go of. That is all.
Aug 09, 2014 | Saeco Odea Giro Espresso Maker -...
I have a 2003 nissan sentra and was having a hard time starting and now won't start.it also didn't have any power would only go 30mph. But won't start at all now.and is reading po731 po732 and...
Well code 1031 is a problem with the O2 sensor circuit which would not keep the engine from starting.
Code 731 is a problem with first gear and 732 is a problem with second gear, and again neither code should keep the engine from starting.
You may have a computer problem, or something going on with one of the wiring harnesses.
Have you figured out if you are lacking spark or fuel to keep it from starting ?
May 09, 2013 | Cars & Trucks
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Screen stuck at home address won't continue with any route, even when I go back and manually enter other addresses, was working great for 6 months
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 18, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
How do i unlock my toshiba labtop
hello sir
It's very Easy.. nera the ram u can see small jumper short the jumper for 15 second with flat screw driver.. if same problem ..do again but keep short jumper and turn on laptop for 15 second .... Thanks
Oct 21, 2010 | Toshiba Satellite M305D-S4829 Notebook
My inspiron labtop won work
If you don't have a backup, then it's time to reinstall Windows.
Dec 14, 2009 | Dell Inspiron 1525 Laptop
ACER LABTOP
usually does this when it has failed to shut down properly, you should get an option to start windows normally or try repair.
Sep 14, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
