I've installed the printer driver successfully and my computer detected the printer. But when I did a test print from my computer it is not printing at all.
When I manually do a test print from the printer itself, it's OK but no when I print it from my computer.
Please help rectify.
SOURCE: Konica Minolta Di1610 can't print
this printer can only be connected via usb to a local computer, unless it has a network card called the N C-5.
SOURCE: konica minolta 750/600 pcl: How do
hmmm...well..there's a set up and installation guide. do you have one?
http://tinyurl.com/6qcpgy
SOURCE: Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: i am looking for drivers for konica minolta 1600f
check this link for the drivers which you are looking for.
http://onyxftp.mykonicaminolta.com/download/Search.aspx
i have installed that in server. i can see the printer on that. when i'm giving test print it's not coming. i can see printer emblem on task bar for a second. the printout is not coming.
Please solve this
