Question about Video Game Consoles & Games
Paragon Pinball machine by Bally. Unit has been in storage for 10 years. Got it out, replaced bulbs, bumpers. Worked great. Week later the ball had got stuck, (which it had in the past) above the "waterfall" as usuall I would give it a nudge to loosen the ball. This time, all the lights on the playing field, and saucers went out. I checked all the fuses in the unit. I contacted a pinball machine repair site. I got this message: You probably have a broken wire under the playfield that daisy chains the GI lamps together. When the daisy chain is broken all the lamps down stream go out. Raise the playfield and you will find a broken wire somewhere near where the lamps are out. Some of the early games had the daisy chain wires too close to the outer edge of the playfield and they would get broken from raising and lowering the playfield over the course of 30 years. Good luck, I checked all the wires that are in the field, and cant find anything loose or broken. Here is a link to the machine: http://www.xmission.com/~daina/images/paragon.html The saucers are the 4 round "bumpers" that you see on the field. The other lights are around the perimeter. While the lights that "score" are work. Obviously a different circuit. Appreciate any help
3 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: nearest repair outlet near glasgow
Couldn't find any pinball machine repairs in Scotland, however I did find a repair service who are willing to come to you. Click on the link below for an idea >>>>>>
http://www.pinballmania.co.uk/repair.htm
Regards.
Posted on Aug 15, 2010
Testimonial: "thank you for reply.unfortunatly no repairs in scotland but shall try the link given"
  • 40 Answers
SOURCE: We have a Mattel Las
Strongly suggest checking the power supply for bad diodes and/or bad electrolytic capacitors.
Posted on Mar 10, 2012
My whitewater pin keeps on blowing fuse F114. display read check fuses F114/F115. Changed 114 but keeps on blowing.
Pinball problems are commonly discussed on pinball forums. For your case go to http://pinballbash.com/forum/index.php?topic=2526.msg23570#msg23570 and look for a very long append from VisitorQ. He gives a nice detailed description of the possible causes.
Aug 22, 2016 | Game Room Guys Flipper Opto Board Williams...
Tip
Flipping pinball flippers like a pro
Growing up my dad was a pinball machine collector, so we always had machines in the house and at a young age playing pinball was one of my favorite pass times. After spending many long hours playing and flipping those little flippers like a manic I realized that there was an art to using the flippers.
When it seems that the ball was going to go straight down the center of the playfield I would use both flippers to try and stop the ball from draining, but it was an action that never worked. I discovered that using only one flipper helped me to catch the ball more often. And this also helped me to discover that you don't need to flip the flippers as often as you might think.
The game of pinball is all about timing and aim, there was one time that I discovered that if I raised the flipper at just the right moment I could bring the ball to a dead stop. This gives you the ability to better control the ball or even take a short break so long as you don't take your finger off that button. You will learn after the first few times playing pinball that it is not a game of random chance that the ball hits places on the playfield and win points but that there is an element of aim involved. With practice you learn the playfield well and the power that you need to hit the ball with to hit the targets. You will find that using a certain part of the flipper will cause the ball to go exactly where you need it to.
Pinball is a very fast paced game, in some instances the ball can be moving at speeds of 20mph! With this in mind when you successfully hit the ball you should immediately let the flipper fall. Holding the flippers up when you don't need them leaves a gaping hole in the center of the playfield and makes it harder to hit the ball if it comes down fast.
With time and practice you too can master the art of being a pinball wiz and amaze your friends with your unbelievable high scores.
on Oct 13, 2013 | Video Game Consoles & Games
My mr and mrs pacman pinball machainght flipper not working what should I look for?
Bally uses an end of stroke blade switch for their flippers. Lift up the playfield and look for the blade switch associated with the right flipper. If there is a wire off or they are broken then resolder it or change them and it will be fixed. If you don't see any problem then put a jumper across the connection and see if it works. DO NOT LEAVE IT ATTACHED. If it worked then change the blade switch. Other possibilities are a bad solder connection on the Solenoid driver board or a bad flipper coil itself. Hope this helps
Dec 07, 2015 | Video Game Consoles & Games
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
All balls shot out
I need to know what machine are you working on? Different era machines have different answers.
Feb 08, 2014 | Bally/Midway/Williams Video Game Consoles...
Pinball machine won't start game, says looking for pinball and won't start game
This means the game does not find the balls in the machine. First look all over the play field and see if a ball is caught someplace. If so, remove the glass and get it out so it will drain. If you cannot find it, see how many balls are in the ball return trough and if it the correct number. If it is the right number, then one of the switched is probably going bad in the trough. Without the name of the game, I cannot tell you if it is a micro switch or an opto switch in the trough.
Dec 30, 2013 | Video Game Consoles & Games
Im looking for a 1978 bally's fireball manual
Bally made Fireball in 1972 and 1976
They made Fireball II in 1981 and
Fireball Classic in 1986
some of the manuals can be downloaded for free
from the net just search IPDB on the web
Aug 10, 2013 | Video Game Consoles & Games
I have a Williams Aztec pinball machine that has always worked well. It is a fairly old 4 player reel type. Today I turned it on, and everything looked like it should (minus a few blown bulbs) I dropped a...
there are about 8 plastic dials all in a line under playfield try moving one with the power on they will move and reset my machine did the same thing and i got a guy out to fix and that is all he did use caution and use a non conductive device in case you touch the wrong thing ELECTRICTY HURTS!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 16, 2010 | Williams Video Game Consoles & Games
Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
SEYLEVITT@JUNO.COM
HOPE IT HELPS.
May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
Video Game Consoles & Games Logo
194 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
