Question about Brother HL-2040 Laser Printer
Brother 9440cn replace toner message override
Does anyone have a "fix" to continue using a toner cartridge after the machine tells me to replace it?
Is there any possible problem to the machine if a cartridge is used until it is completely empty?
  • 3 more comments
  • doddcomps Nov 28, 2008
    Thanks Stuart1982 for the quick reply.
    I cannot see any electrical contacts for an electronic sensor, so I am thinking that there may not be an electronic detector.
    There are2 circular windows, one on each side of the cartridge that can be covered by toner if the cart. is tipped on its end. Other threads on this forum talk about covering a window with black tape to fool the machine into thinking that there is enough toner.
    Anyone have any ideas if the machine is damaged if toner runs out completly?
    This question was put into the wrong printer category. Sorry. I have repeated the question in Brother9440cn category
    Thanks again. Unfortunately, I have already replaced the old carts with new ones and disposed of the "empty" ones. At the end of the new cart's life, I will definately be trying this trick.
  • doddcomps Jan 27, 2010
    found a solution:
    undo the two screws at the end of the cartridge. there is a wheel and spring acting like a cam. Turn this wheel (cannot remember which way -- and you need to first take out a white geared cog wheel) which tells the printer that the cartridge is not at the end of its life
  • Anonymous Mar 31, 2014
    I have a Muratec MFX-1450. . . The Alarm says "Toner should be replaced". . . We replaced the toner, but it still says "Toner should be replaced". . . Is there a trick??
    Problem Solver:
  • 15 Answers
Well you could shake the toner cartridge, to make sure that the remaining toner has uniform coverage to the developer roller, which is the black magentic roller in the toner, which applies the toner onto the drum.
Only way to fix, if the printer uses a electronic sensor, is to actually change the toner, it can not be overridden.
Posted on Nov 28, 2008
Testimonial: "THANKS FOR THE TIP"
    Problem Solver:
  • 15 Answers
It shouldnt damage the machine, it would just cause print quality problems, like white streaks down the page due to lack of toner.
place the black tape on the windows and shake the toner side to side.
Testimonial: "THANKS FOR THE TIP "
Replacement toner cartridge not accepted
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 11, 2012 | Brother Toner Cartridge Tn350 for MFC7420...
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
After refilling the cartridge the toner low red light is still flashing. How to stop the flashing light?
Did you remove the plastic tab from the toner cartridge?
It would not be the first time I have been called to a faulty printer to find the cartridge had not been correctly installed.
You say in your post that you refilled the toner. Did you replace the whole cartridge or pour toner into the machine?
Every machine has different toner have you checked that it is the correct type?
Also some cartridges have a chip embedded that tells the machine that it has been replaced it is possible that this has failed either in the cartridge or within the machine.
Jul 03, 2009 | Ricoh Multifunctional SP 3200SF...
Lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
Jan 19, 2009 | Lexmark E250dn Laser Printer
Can a cartridge be "fixed" to continue use after "replace toner"
Yes, tthe machine shines a laser through the cartridge to tell that it is empty. However, I do not believe that there is anything that you can do once the add toner indicator has come on. The best theing to do is to avoid the add toner indicator by the means you described. I would not advise tipping to one side as that will eventually lead to uneven coverage. Instead, try turning it a few times then re-inserting it back into the machine.
I hope you find this information helpful.
Nov 28, 2008 | Brother MFC-9440CN Laser Printer
Printer won't recognise new toner cartridge
Is the new cartridge made by Epson? Also check the contacts on the cartridge and in the printer where the cartridge contacts mate. Sometimes there is foreign material that blocks the signals. It's also possible that you have a defective cartridge. Check with the place you bought it.
Oct 29, 2008 | Epson Aculaser C1100 Printer
Brother 8460n - toner error
Hi, This worked for us:
The message "Toner Error" is usually caused by the drum and/or toner
cartridge not being installed properly or if the machine does not
recognize the toner. To clear this message, follow the steps listed
1. Verify you are using Genuine Brother Cartridges. Brother strongly
recommends that you do not refill the toner cartridges provided with
your machine. We also strongly recommend that you continue to use only
Genuine Brother Brand replacement toner cartridges. Use or attempted use
of potentially incompatible tone cartridges in the Brother machine may cause damage to the machine and/or may result in
unsatisfactory print quality. Our warranty coverage does not apply to
any problem that is caused by the use of unauthorized third party toner
and/or cartridges. To protect your investment and obtain premium
performance from the Brother machine, we strongly recommend the use of
Genuine Brother Supplies.
2. Make sure that you are using the correct drum and toner cartridge(s)
for your machine. The part numbers for your model are as follows:
NOTE: Some cartridges can look EXACTLY the same among different models
and will fit the machine even if they are not designed for use in that
model. Verify the part number before using the cartridge(s).
TN550: Toner cartridge (standard)
TN580: Toner cartridge (high yield)
DR520 = Drum unitt.
3. Make sure that the cartridge is not damaged. Remove the toner
cartridge by following the steps listed below:
a. Press the cover release button and then open the front cover.
b. Remove the old drum unit and toner cartridge assembly. Place it on a
drop cloth or disposable paper to avoid scattering toner.
NOTE: Be careful not to spill the toner. If toner gets on your
clothes or hands, wipe or wash it off immediately with cold water.
c. Hold down the blue lock lever on the right and pull the toner
cartridge out of the drum unit.
d. Look at the toner cartridge and see if any parts or pieces appear to
be broken or missing, if so, the cartridge may be defective and should
be replaced.
4. If the toner cartridge is not damaged, reinstall it into the drum
unit. If it was damaged, use a new toner cartridge and reinstall it into
the drum unit.
5. Reset the drum/toner unit into the machine.
6. Close the front cover.
7. If the message "Toner Error' continues to appear on the display
unplug the machine from the wall outlet.
8. Open the front cover and remove the drum and toner assembly.
9. Look inside where the drum was. On the left side wall, look for a
small, black plastic lever/actuator. A flashlight may help see it.
10. Using the palm of your hand, slide it along the left wall in and
out a few times as this may free up the actuator/lever in case it is
stuck. The actuator/lever is spring loaded and needs to move back and
spring forward to operate correctly.
If the lever does not move, spring back or is missing and your machine
is within warranty, you can locate a Brother Authorized Service Center
(ASC) in your area or contact Brother Customer Service by calling
1-877-Brother (1-877-276-8437) Monday through Friday, excluding
holidays. If the machine is out of warranty, you can locate a Brother
Authorized Service Center using the information listed above.
If the lever moves freely and springs back to its original position
continue to Step 11.
11. Reinstall the drum and toner assembly, close the front cover and
plug the machine in.
Aug 12, 2008 | Brother MFC-8460N Laser Printer
Brother HL-2040 Laser Printer Logo
946 people viewed this question
James Cagle
James Cagle
Jim Keysor
