Question about Frigidaire FTF530FS Front Load Washer
Can't close door - Frigidaire FTF530FS Washer
The lock mechanism won't let me close the door - appears to be in lock mode although machine is off (button pushed in and door lock light not lit). I've had this machine a month. I had this model before and never had this problem. Any ideas of how to correct this?
  • Anonymous Jan 01, 2009
    I am having the same problem. I've the washing machine for 3 yrs and it is always and issue with the washer or dryer. Once we get both fixed I am thinking about selling them and getting a top load washer. This washing machine and dryer is a piece of junk!
  • 116 Answers
REPL/ DOOR SWTICH LOCK MECHANISM....
Posted on Nov 30, 2008
Frigidaire FTF530FS Front Load Washer will not advance through cycles... need to manually turn knob. New timer did not do the trick nor control panel...
Hi Jacquie, thank you for your inquiry! First, when you are referring to the control panel are you speaking about the motor control board? The motor control board advances the timer, and the timer will not advance if it does not sense that the door is closed and securely locked. Therefore, I highly recommend reaching out to an expert technician that can accurately diagnose the motor control board and/or door switch on this particular unit. The servicer will ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 10, 2013 | Frigidaire FTF530FS Front Load Washer
Amana he washer door won't close
Bad lock mechanism, without proper model number I can't give accurate instructions.
Jun 22, 2012 | Amana Washing Machines
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
My ftf530fs has worked every time I've used it, but tonight when I closed the door it would not start. The door lock light is on, but it will not start on any setting. What do I need to do?
My GE front loader did this. I unplugged/plugged it in and it started. Weird, but I hope your solution is that simple. Also, check your breaker.
Nov 15, 2009 | Frigidaire FTF530FS Front Load Washer
Broken electronic connector on washing machine
seawolrf your going to have to do a little work...open the door now looking at the washer i want you to take a knife or screw driver and take that gasket off right next to the door switch,,the black gasket is glued ,,yes glued pull it up..only by door switch..now remove door switch screws (2) now replace that connection...onthejob
Jan 27, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
258 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
