Question about Navico Lowrance Thst Dfbl Bronze Th 106 79
Service manual for Navico DS200
I need a service manual for Navico DS200 depth sounder meter
  • Jerry7777 Jan 22, 2009
    I need a transducer for a Navico DS200 echosounder, or at least the spec of the original to enable me to find a suitable alternative. Can anybody help me please?
3 Suggested Answers
SOURCE: I need a replacement transducer for a Navico DS 200 Depth Sounder
my ds200 has stopped
if i find it only way to replace you can have the removed transducer
cheers colin jewellersbench@talktalk.net
Posted on Dec 09, 2008
computus
  • 487 Answers
SOURCE: Need a service manual for a Navico 8000 auto pilot
Hi, I have found this link, its american, let me know how you get on!
http://www.marineelectronicshoppe.com/Manuals/Simrad/Autopilots.htm
Posted on Jul 26, 2010
I went out to the continental shelf fishing in depth of 250 meters . My echo sounder is a simrad nss evo 16. I had problems while drifting the sounder would freeze how can I fix this
I did a search and found this as I don't own one not sure if this forum will help or not but thought I'd pass it on anyway.
Best to you.
https://www.thehulltruth.com/marine-electronics-forum/645739-problems-simrad-nss-evo2-chirp-structure-scanner.html
Jan 11, 2018 | Simrad Boating
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Faria Depth finder
I've found this manuals in Faria's site:
Depth sounder:
http://faria-instruments.com/site_manuals/IS0091F.pdf
Bombardier Depth Sounder:
http://faria-instruments.com/site_manuals/IS0138_C_digital_depth_sounder_owners_manual.pdf
Depth Sounder, Flushmount:
http://faria-instruments.com/site_manuals/IS0141c.pdf
Depth Sounder, Flush Mounted, Remotely Switched:
http://faria-instruments.com/site_manuals/IS0229_A_Digital_depth_sounder.pdf
there are also other useful manuals in the bottom of the page:
http://www.faria-instruments.com/downloads.php
Jul 14, 2008 | Faria Boating
Si-tex cvs 106 mk11echosounder
To re-program the Si-tex CSV-106 depth sounder to feet/meters/fathoms: Push and hold down the MENU key while turning the unit on (POWER key) to enter a special menu. Release both keys after you hear two beeps, almost immediately. Use the LOWER ALARM key to select the desired unit for depth, then turn off the depth sounder. That's it, just turn on again to see the change.
There is also another menu (for testing sounder) available by pressing the MODE and turning on as above.
Apr 26, 2008 | Computers & Internet
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Jrc ff30
Wiring diagram for JRC ff30 sounder, transducer.
Aug 20, 2007 | JRC 1800CP GPS Receiver
Navico Lowrance Thst Dfbl Bronze Th 106 79 Logo
737 people viewed this question
Top Navico Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Navico Boating Expert? Answer questions, earn points and help others
