Question about Roland Vs-2000CD Digital Studio Workstation System
Corrupted file blocks boot
I have a Roland VS2000,,, song file is corrupted and wont let haard drive finish booting... Tried deleting but have been unable. Booted Recorder with another computer and again tried todelet corrpted file and it won't allow.
what do I do now. I have been blocked and can't do my work since the recorder wont run.
  • rjb1922 Dec 27, 2008
    I have a similar problem if not the same problem. While trying to create a new project, I pressed store current project and somewhere within the process lost power. the VS2000 is trying to load one of the projects - not sure which - on bootup and can't finish loading.
    how did you boot the VS2000 with another computer?
    Problem Solver:
  • 6 Answers
Fro what I know its in a FAT 16 or 32 format, for the one who booted with other pc try to Move the file, at times it wont let u del but it'll move it to other pc if u can, if that dosent work yet if you can see your vs-200 40g small HD try to format it it shuld work, the boss/roland people shuld have given formating or reseting tools or shuld have them for free downloads, if not get the hard disk out plug it in other pc or portable and do as u like if its SCSI old and slow the so caled new then is older then my grandfather yet SCSI's are relible anyhow than you wont need controler card, you can do a lot, I am teling every one, they dont put inf memory and disk space, if the drive is compresed it dosent meter we want uncompres, I wrote all this couse you say you can boot with other pc, oh, a croslink files can be a problem mbr can be deleted and redone. good luck
Posted on Jun 22, 2009
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
My dell inspiron 6000 wont boot up. error message Windows\system32\config\system is missing or corrupt
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Oct 26, 2010 | Dell Inspiron 6000 Notebook
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Compaq presario 5400t was running out space on hard drive so i added a seagate external hard drive. after copying over files i deleted them off of the internal drive and must have inadvertantly deleted...
use your xp disk, boot from cd then rather format, select the F option to repair.
it will rewrite your windows folder without deleting other personal folders
Jan 02, 2010 | Computers & Internet
Roloand vs2000 hard drive crashed... where to get a new one or fix this one? We were recording and tried to play back, system them never booted and gets stuck while rebooting. Tried a new hard drive but...
Roland has excelent Tech support.
I might try with the Web site below -
Please let me know what you find and or re-contact me if you can't get anywheres with Roland only I think they will be more than happy to help.
A/V Media Guy
Nov 22, 2009 | Roland Vs-2000CD Digital Studio...
Emachines notebook m5310 corrupted bios recovery
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
Flash an appropriate BIOS to the corrupt BIOS and reboot.
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at
Solution 4: (for Intel motherboards)
Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
Install the bootable upgrade diskette into drive A:
Reboot the system
Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
Turn the system off
Change the Flash Recovery jumper back to the default position
Leave the upgrade floppy in drive A: and turn the system on
Continue with the original upgrade
Oct 14, 2009 | Computers & Internet
Tracks showing up double
about the a-z thing, i dunno.
about the deleting part, it depends where you're deleting it from.
if you listen to it in play all and delte it from ther, it wont work. you have to find it in the shuffle mode (very annoying, i know) and delete it there. good luck.
Apr 02, 2009 | Creative Labs Zen Digital Media Player
Cant turn my phillips pss110 after taking it out of the computer
does the device immediately shut off after displaying the Philips boot screen? if so, the mydb internal database file may be corrupt or missing.
Get the free program "ShoqBox Buddy" and use the "rebuild database" function to see if that fixes it.
Nov 03, 2008 | Philips PSS110/17 MP3 Player
Winxp cannot boot - missing files message
Just make sure you get these files on your computer.
Download hal.dll from here:
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Roland Vs-2000CD Digital Studio Workstation System Logo
250 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
