Question about Sony PFM-500A2W 42 in. Television
My monitor fails to start and the power pack shows 12-22 repeatedly
Hi I switch on my monitor it goes to start up for a second or so the fan starts to run, it fails to start, the screen with the power pack repeatedly alternates 12 to 22, sometimes I get a quick flash of 53 it then goes to 99 and stays there. I do not have a manual so can't tell what the numbers mean.I hope you can help. best wishes Tesz
  • ROYALTY May 22, 2008
    WHEN I TURN IT ON THE FAN STARTS AND THE MONITOR GOES OFF AND COMES ON CONSTANTLY, WHILE GETTING A 12 TO 21 CODE AND WHEN IT GOES OFF THERE IS A BLINKING DOT.....HELP!!! PLEASE!!! WHAT IS THIS A DISPOSABLE MONITOR?????
  • lm80lm Dec 18, 2008
    MY code is 12 so what is my monitor doing.
Howdy, I guess you're talkin' about a : Sony PFM-500A2W Plasma screen ?? The fault-codes your talkin'about " 12/22 " + continue re-starting " is a common problem with those plasma screens. It gives an " low power " message on the PDP module . We started today a discussion-group at google.com to get a clear picture at the Sony. We allso placed a " fault-code " list , so users can see what those codes are standing for. The main target of the discussion-group is ..... sharing knowlegde and information about the Sony PFM-500A2W. Schematics Problem solving fault finding Where to get any kind of parts. Print layouts etc. etc. The followin' link shows the discussion group. Please give us some time to startup the group. So don't give up any hope ;-) http://groups.google.com/group/SONY_PFM-500A2W Best regards , EuroNet 2000 The Netherlands
Posted on Feb 28, 2007
Samsung HLP466W goes off after turning it on for about 20 seconds, why does it do that?
The power supply tries to start for about 20 seconds, then fails. It will repeat this routine until eventually it fails competely.
Jul 15, 2014 | Samsung HLP4663W 46-Inch Widescreen DLP...
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
May 17, 2009 | Gateway 310 X (310XSP) PC Desktop
The sd card reader in hp compaq nx6125 is not working
dear it is damaged...please replace....when this message show then memory card is damaged and not readable or not writeable.
Apr 23, 2009 | HP Compaq Business nx6125 Notebook
Boot everytime
POBLEM WITH THE MOTHERBOARD...SORRY...
IF IT IS WITHIN WARRANTY TRY GET IT DONE THRU VENDOR IT WILL SAVE MONEY
May 22, 2008 | HP Compaq nx6125 Notebook
Red light(HDD) continuosly glows but system does not start, even monitor not detected
Hi, have you checked inside your computer with the power on? The problem may be as simple as the cooling fan on your heatsink not working. also check if you have a case fan and see if that is working. If these are running, then check that ALL POWER CABLES TO THE MOTHERBOARD are plugged in tight. If all this fails you will need to test your power pack. If you have a multimeter test that the power cables to the board have power, Grey is neutral, black negative and the rest are either 5v, 6v, or 12v. If you can not do this test then swap the power pack from your other computer and see how this works, let us know if this fails Regards mistyman
Aug 25, 2007 | Intel D845GVSR Motherboard
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Sony PFM-500A2W 42 in. Television Logo
237 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
