WHEN SWITCHING MY MFC =240C PRINTER i AM ASKED TO ENTER TO ENTER FAX NO AND CONSEQUENTLY I CAN'T PRIT. pLEASE SEND ME THE STEPS TO STOP THIS REQUEST SO THAT I CAN PRINT. THANKS
  • jackierus Dec 17, 2008
    but how to solve it finally?
My problem was fixed with the assistance of a" home grown" techical
expert, my sont.
Thanks for following up
Ted Brabers
Posted on Nov 29, 2008
I can't receive a fax i can send one but cant receive
Hi there!
You can try checking on these steps to resolve your issue:
1. Make sure that you have the normal screen on the LCD ex. date/time FAX (Receive modes can be TAD, MANUAL, FAX/TEL) Please take note of the display.
2. Just to double check press Hook to verify if you have a dial tone.
3. Make sure you have the correct Receive mode on your screen
4. To change the Receive mode to the correct receive mode just press Menu 0,1 then press the arrow keys to select the correct Receive Mode press OK to choose your selection & press the STOP/EXIT key to go back to the main screen.
Hope this helps!
Rate if it works
Thanks!
Mar 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
How to clear the memory on a brother mfc-240c-- error when faxing is out of memory
You can also try to send the fax with Real Time Transmission ON so that memory will not be full.
Sending in real time for all faxes
a Make sure you are in Fax mode . b Press Menu, 2, 2, 3. 3.Real Time TX Realtime TX:On
c Press a or b to choose Realtime TX:On or Realtime TX:Off.
Press OK.
Please click Yes if this helped
Thanks,
vikroks
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
How to set the date and the time in brother fax mfc-8220? what's the steps?
Your MFC displays the date and time and if you set up the Station ID
it prints on every fax you send. If there is a power failure, you may
have to reset the date and time. All other settings will not be affected.
1 Press Menu, 0, 2.
2 Enter the last two digits of the year.
Press Set.
3 Enter two digits for the month.
Press Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day.
Press Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the MFC is in
Standby mode.
thx, if this helps please rate :)
Jan 27, 2011 | Brother MFC-8220 Fax
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Dec 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
How to change fax speed from14.4 to 9600
The machine does this automatically on connection. It negotiates a reliable connection speed with the recipient machine and then transmits data. If in encounters an error repeatedly it will negotiate the speed down even further until the data can be sent successfully. However the following menu setup option may help
Main MenuFaxSetup SendOverseas ModeOn will change the speed down to 9600 max and negotiate downwards if required.
Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Lost Manual
Hi - You can download the manual by clicking the link underlined in blue below:
MFC-240C
See page 24:
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 01, 2008 | Brother Multi-Function Center MFC-240C...
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
27 people viewed this question
k24674
jasbo
jasbo
