Question about Marvel 25IMBS
Broken marvel 25IM-BS icemaker
How do I fix a marvel icemaker with broken relay sensor
    Sergeant:
    Champion:
  • 311 Answers
What is the relay sensor???? I know of no part on that machine that is called that. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Why is the icemaker leaking
Sediment has built up on the water valve. Or someone put something in the icemaker to cool quickly such as soda or beer and when the ice mechanism cycled something got bent causing a leak.
May 16, 2016 | Marvel 30iM 120V Ice Maker
Our Marvel icemaker was working great then it starting making ice at a much slower pace. It is not make ice no where near as fast as it was. What could be the problem?
Could be a dirty condenser coil, blocked return air, if the ice machine is in a warm environment it takes longer to make ice, water temperature if it is warmer it will take longer to make ice. if water inlet valve is letting water seep buy during freeze cycle it will take longer to freeze.
Dec 17, 2012 | Marvel Appliance Ice Maker
The temp. sensor displays the wrong temp.
Dear Sir/Madaam,
The 6SBAR-BS-G does not have a digital temperature display. Could you provide your correct model number? The 6SBARE-BS-G does have a digital display and has two temperature sensors.
One is used for control and the other is used for display. The are connected to the back of the display board by small white molex connectors. The smallest is for (two pin) is for the control and the three pin (although only two of the pins are used) is for the display.
The unit does not have to be removed for it's installed location to change the thermsitor, (temperature sensor), but you will want the power off when you swap it out.
You can order a new sensor from a few sites on line but the best thing to do is call the factory direct at 800-223-3900. The part number for the display thermsitor is 42246463 (the control thermsitor is 42246462). If your unit is more than a year old you may wish to replace both sensors while you are doing the work. If you are doing the work yourself, ask the customer service technician if he/she would email you the service manual as well.
Let me know if you need any further assistance - Subdriver
Feb 13, 2010 | Marvel (6SBARBSG) Wine Cooler
Ge profile refrigerator PSS27SGNA BS....unit's refrigerated section keeps freezing food. even after we've adjusted the temp up to 36 or 37(recommended) it stays at 30 and keeps ruining the produce.
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Feb 03, 2010 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Icemaker is not making ice. after reinstall, icemaker runs with no water and is not making ice. seems timer and relay are not in sinc.
remove the white cover on the icemaker may come off hard do you see a white round cam there should be no broken retainer holding it on if it is broken motor moldule is req ..... doe's it have an metal plate under the white cover if so check the cams 1 small 1 large to see if any of the teeth are broken if so replace the icemaker
Aug 19, 2009 | Kenmore Refrigerators
Unit does not run due to faulty thermostat.
The 6SBAR-BS-G most likely has the solid state thermostat that consists of three parts: A solid state control board, a 0-100K potentiometer (connected to the control dial) and a thermistor. The thermistor is the most common part to fail. I would call the factory and ask for technical assistance to help isolate which part has failed. Most service companies do not stock their parts. The factory's number is 800-428-6644 or write an email to marvel@marvelindustrie.com
Jul 29, 2009 | Marvel (6SBARBSG) Wine Cooler
Marvel undercounter refrigerator, works for a few days then stops
I experienced same problem with my refrigerator, Marvel ar61. Call Marvel and they will send you a repair kit which includes a new thermostat, switching relay and a new thermistor. My refrigerator is working great.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Marvel 6barbd undercounter fridge
marvel 6sbar-BD with wine storeage racks on the bottom and two glass shelves above. If I put sodas on the top shelf they expode. I have it on the lowest setting. Please advise.
Dec 22, 2008 | Marvel 6BAR-BD Beverage Cooler
Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Nov 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Marvel 25IMBS Logo
150 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
