Question about APC Smart-UPS UPS System
UPS constantly sounding an alarm tone
I bought this UPS for our NGO office. It started to make a high pitched tone (as if it were overloaded) almost from the start. The tone goes starts from the moment you switch it on, even with no load on it, and will continue even when it the UPS is switched off. The only way to stop it is to hold the off button in for 5 seconds or remove the battery connector from the rear. Unfortunately I installed it the evening before I went on leave, and came back to find that the alarm had been going for almost 3 weeks, and that the cleaner had thrown away the box and all documentation, including the software. Obviously it cannot be used while making the sound unless you are looking to give yourself a serious headache. Suggestions please.
    Problem Solver:
  • 7 Answers
Http://www.apcc.com/resource/include/techspec_index.cfm?base_sku=SUA1500&tab=documentation Above is the site for your operators manual and troubleshooting guide. Not knowing how load the sound is makes it hard to tell you what to do. You may have a damaged UPS.
Posted on Jan 25, 2007
Pac makes continous sound
What is the sound? Is the device working normally? Are there any lights or indicators? Do they indicate a fault or error?
A UPS runs on standard 110-120 VAC power. It converts the input power to DC and charges internal batteries, then back to AC. Connected devices actually run on the conditioned 115-120 VAC output. The batteries serve as a short term backup power source.
The electronics in the UPS can produce hum or high pitched tones. The sound should not be annoying. If it is louder than connected equipment (computers) it may indicate a problem. Hum is usually 60 Hz harmonics and difficult to eliminate. This harmonic may be transferred to audio equipment such as speakers or radios. A high pitched tone can be related to the rectifiers for the convertor/invertor. If the tone is loud, it means the rectifiers are drawing a lot of current. This is usually related to bad batteries.
Measure the voltage on the output receptacles. It should be 115-120 VAC. Disconnect everything on the output receptacles. Unplug the UPS from it's power source. If the output power dies within 1 minute, the batteries need to be replaced.
Jul 19, 2012 | APC Computers & Internet
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
Constant beep even while driving and when i turn it off it still beeps unless i disconect the interior lighting fuse and plug it back in fuse # 8 i believe. if i leave the fuse out it makes a wierd sound...
1995 GrCher Orvis - I have now just started with the same problem. An incessent loud high pitched alarm sound. Identical fuse, ignition on/off, and ticking issues. Can start jeep, warning sounds as normal followed by incessent tone, I can remove fuse to get quiet, but then when I close the door I get the identical alarm sound, but with a slight pause. Tone. Tone, Tone, etc. I can't figure. Tore through all components of dash: to learn that the alarm seems to emminate from the transmission floor area, and is not in the instrument panel (f up #1) nor is it behind the dashboard (f up #2). I'm stuck now... Anybody got something for me? Is it a transmission warning?
May 28, 2010 | 1995 Jeep Grand Cherokee
Tone alarm goes off and flashes "overload" and on the back "building wireing fault" is lit up
The "Overload" light and alarm is to tell you that the devices connected to the UPS are drawing more current than the UPS can safely provide with battery backup. You should disconnect a few items, and the alarm and overload light will turn off. The "Building wiring fault" light on the back is to tell you that there's no proper ground wire inside the wall outlet that you're using. These two problems are not related to each other.
Mar 04, 2010 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Oct 21, 2009 | APC Back-UPS XS900 (BX900) UPS System
High pitched tone comes on whenever radio is turn on
Hi,welcome to fix ya. if this is a bose system you have a bad amp behind the rear seat they short out inside and cause the speakers to emit a high pich squeel. you can buy these amps on e-bay pretty cheaply or send it to bose for repair .
Nov 30, 2008 | 1994 Acura Legend
Apc
1) Switch Off the UPS and unplug all Loads (like System, Monitor etc.) from UPS.
2) Switch Off the AC Power (Input Power to UPS).
3) Press the UPS Power Switch constantly unless you hear 2nd BEEP Tone. As soon as you are hearing 2nd BEEP Tone, Release the Power Switch.
4) This is COLD START of all APC UPS that will reset any internal problem.
5) If, however, the problem persists, contact APC.
Jul 23, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
APC Smart-UPS UPS System Logo
454 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
