Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Darker picture I have a 57 inch Hitachi Projection tv Model 57TWX20B 6 years old. I noticed the picture got darker and darker. I changed the picture mode to Sports and it got slightly better. But I had to adjust the brightness to a 100% to make it look better but it is still not the way it should be. I have had it serviced for 5 years and vever had this problem. Now that the service plan has ran out I get a problem - Go fiqure
  • dfischerman Dec 16, 2008
    Yes I have almost the same problem. I was watching in the morning and the picture was fine. My wife and I left to do a little shopping and came back about 4 or 5 hours later, I turned on the tv and noticed that any dark colors or black was really dark. If there was a seen at night you could bearly make out what was going on. its not getting any worse but it doesn't get any better either.
  • matrix340112 May 26, 2009
    I have the same exact problem.........
    Genius:
  • 1,199 Answers
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Posted on Dec 08, 2008
How to fix fix my Hitachi Projection TV - model # 61WX01W, got darker and darker and now all dark. Has 3 pictures tubes. How do I fix the problem?
Likely what you have is the three tubes each have a filament--not unlike a light bulb-----someone would have to trace the filament voltage (usually comes from power supply) from source to the three tubes---filament connects to each tube with two connections and is usually 6.3 volts.
May 05, 2012 | Hitachi Televison & Video
How to fix my hitachi 65 tv
If you are saying that the picture is getting darker and you have already tried to adjust the picture through the menu feature on your TV then it is more than likely the cooling fluid around the CRT tubes. Over time the fluid in these tubes gets cloudy and causes your TVs picture to become dull and distorts the color. You can google tv repair kits .com and I believe they will have a kit for your model.
Feb 21, 2012 | Hitachi 57F500 57" Rear Projection...
The picture seems to be getting darker. Its not as bright and sharp as it used to be. Its about 9 years old but has not been used very much. Might it need a new bulb or something? 57HX81 Proj TV Color...
simple: remove back cover and locate the three large black lens you will see top and dead center, clean them with either a lens cloth or a paper towel with glass cleaner----they are the light source for your picture and should be cleaned once a year---as they get dusty the picture gets darker and duller looking.\\
SD TECH
Apr 12, 2011 | Toshiba 57H81 57" Rear Projection...
Does the Hitachi 57TWX20B have a replacable light bulb?
Yes,Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for ur tv.
Jun 24, 2010 | Hitachi 57TWX20B 57" Rear Projection...
Screen going darker and darker
bulbs might be going out,burnt out maybe
Oct 19, 2009 | Hitachi 57F500 57" Rear Projection...
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
Hitachi 57TWX20B Picture Problem
I just answered this please see my last post
Apr 23, 2008 | Hitachi 57F500 57" Rear Projection...
HITACHI BIGSCREEN TV MDL 57TWX20B APPROX 4-5 YEARS OLD...TV SHUT DOWN WHILE WATCHING AND WON'T POWER BACK UP
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Mar 15, 2008 | Hitachi 57TWX20B 57" Rear Projection...
Hitachi 57f710s
Sounds like a video board problem. May also be the convergence board. You might get some freeze spray ( a component cooler that comes in a spray can ) and while the set is on, spray the boards and see if the problem temperarly corrects. This is to isolate the problem. Once the problem is isolated, you can change the bad component. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 02, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 57f500 blurriness and getting darker
Sound like you need clean fluid and some adjustments.
Dec 21, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
