Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven Model JVM1440BD: turntable doesn't work. When we press start, turntable make semi-loud noise while oven is cooking, but it does not turn. We can stop noise by pressing turntable button.
  • Anonymous Dec 28, 2008
    I have a GE spacemaker microwave oven Model # JE1550GY. the carousal starts rotating when the door is opened. Functions fine in all other modes when the door is shut i.e for heating the carousal rotates and when in standby or idle the carousal stops with the door closed. .
  • GE Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 02, 2008
My ge micro will not stop turning
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
228 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
