Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
French door on right keeps swinging open
Hi, our french door refrigerator is great, but when we open the door on the right it swings quickly to the right. The other door will stay where we put it. It is frustrating. Can this be adjusted so the door doesn't swing so hard when we open it?
  • Anonymous Mar 24, 2014
    how to adjust doors
  • 121 Answers
Yhe leveling of the unit will help
Posted on Nov 29, 2008
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
You do not have to remove the door....swing it all the way open... then remove the shelving... then you are at the back cover...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Nov 27, 2010 | Amana AFD2535DES French Door Refrigerator
How do you adjust the door swing angle on the Viking VCFF036 bottom freeze French door model? What are the angles?
Check with your Viking rep. I had a problem that the door swings too wide. They said they are coming u with a kit to replace the door stop. I was told there will be a 100 degree doorstop kit for my problem The door when swung open gets a ding from an adjacent Viking electric oven with the professional door.
Jan 01, 2010 | Viking VCFF036 Bottom Freezer French Door...
I just purchased a GE profile counter depth french door refrigerator. It seems fine except that the doors (both top and the freezer door) do not swing shut. They have to be pushed to close properly. We...
The doors are out of alignment.
pretty tricky to get right - and professional help is suggested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | GE Refrigerators
French doors - when you close one side the other pops open especially when the door is closed hard
This is normal operation,the new units are very efficient and air tight so when you close one door especially hard you are forcing air into the inside that has to escape somewhere therefor it forces the door that is stationary open just enough for the air to escape,as long as the door closes back afterward you have no problem if the door opens and swings out,then you would have a leveling problem the fridge would be leaning too far to the front.
Sep 27, 2009 | Maytag MFD2560HES Bottom Freezer French...
Right side door keeps on swinging open
Does it have a magnetic gasket? If that has cracked and failed, it's not too hard to replace. If the door is warped out of shape, just push it back.
Apr 27, 2009 | Maytag MFC2061HE Bottom Freezer French...
GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Jan 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
French Door to right swing on Fridge
Go to this link and you can see all the identical sized models with a right swing door. The hinges are the same so you could easily swap them; here's a link to the user manual if you need it; check page 7 and 8 for how to swap a door. Page 20 gives you contact details for spare parts. Hope this helps :)
Jun 27, 2007 | KitchenAid KBFA20ER Bottom Freezer French...
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
769 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
