Question about Canon SmartBase MP390 All-In-One InkJet Printer
Check printer error 343
Waste tank full
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Read this link hope it helps
http://www.inkjethelper.com/inkjetstuff11.html
Posted on Dec 01, 2008
343 printer error
The 343 printer error means that your waste ink absorbtion pad is full. Follow these steps below to reset it:
1. Go to menu by pressing the > button
2. Press [copy] and then #
3. Go to 'test mode' by pressing > several times
when "test mode" is on the screen press the "ok" button.
4. Now press 8 then 3 then 0
5. After that press the on/off button
Feb 13, 2011 | Canon MultiPASS C70 All-In-One InkJet...
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
Waste ink tank full almost full on the canon mp730
These reset procedure will clear the error 343 or waste ink tank full.
1. Press the Menu key
2. Press the Copy key
3. Press the " # " key
4. Sroll from the menu option until you come to " counter ", then press OK.
5. Press Menu and select "clear all"
6. When the message "please wait" appear, press the Menu two times.
7. Restart the printer.
Let me know if this one solve your problem.
Please comeback and do rate this solution.
Thanks for using Fixya.
Aug 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Not responding flashes ##343 on screen
Which model?
If it is a BJ or ink type device, then this error means that the ink absorber for ink test is full.
Turn power off / on
If the error doesn't clear, and the waste ink absorber is full, then it will need to be replaced, and the waste ink detection set to '0' in Service Mode.
Dec 07, 2009 | Canon Office Equipment & Supplies
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Canon MP36 error ##343
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Hope this helps!
Rehards,
HP
Aug 28, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Error code printer check ** 343
the error is "Waste Ink Tank Full" error
This error occurs after a set number of nozzle activations, and it's to protect you from having ink start leaking out of your printer.
The waste ink tank is actually a large cotton pad in the bottom of the machine which absorbs the waste ink, and if this pad becomes full, the ink will pool and, like water, seek the path of least resistance, which could be where the case parts connect, and then leaking out onto your desk or carpet...
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
hope it works for your model
Hope it helps.
goodluck pls dont forget to rate this
Sep 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Feb 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon SmartBase MP390 All-In-One InkJet Printer Logo
51 people viewed this question
old marine
old marine
