Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Removing panel on side by side fridge...
Trying to remove the front panel of side by side water/ice dispenser. Tried to use flathead on two slots on the bottom but will not budge. Fridge is a whirlpool ED27DQ...any suggestions on how to remove the cover?
  • 2 more comments
  • stevenmeliss Nov 28, 2008
    Should I push up with the screwdriver or try to pry the cover off? Another post said something about pushing on the drip pan (water dispenser one) but that didn't do anything.
    I got it! Thanks again.
  • Anonymous Mar 25, 2009
    trying to remove ice/water dispenser
  • huffman12 May 11, 2009
    What is the trick to getting the front cover off my kenmore(whirlpool) water/ice dispenser? I don't want to break it.
    Sergeant:
    Champion:
  • 311 Answers
It comes off just like you are doing- it snaps on, so it needs to pop off at those spots first. Please leave feedback.
Posted on Nov 28, 2008
How do I remove the front dispenser panel to replace the ice path shutter?
On the bottom edge of the panel there are two tiny slots in the plastic. Take a flat blade pocket screwdriver, insert the blade in the slot and pry it off .
Jan 01, 2016 | Beko GNEV321APX Stainless Steel 526 l...
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Dispenser leaks from rear of fridge
the answer to the problem is behind that back panel.
Nov 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Oct 10, 2009 | GE Profile CustomStyle PSI23NGR Side by...
GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Apr 01, 2009 | GE PSS26SGR Stainless Steel Side by Side...
Frigidaire FRS26ZSH no water at dispenser or ice maker
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Aug 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Sears Kenmore Refrig #363-9554710 (side by side) - Remove panel on left front to access funnel guard
You will need to unplug the fridge or unplug the wires going to the dispenser from behind the grill at the bottom of the fridge.
Pop off the front cover over the switches and pop off the soft button cover that you mash to activate the dispenser.
You will see the screws that hold the dispenser assembely to the housing. remove them and the unit will slide toward you.
Post back if you need more help, I may have forgotten a step somewhere.
Oct 30, 2007 | Refrigerators
Water dispenser keeps running
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the problem...Catriver...post back.
Dec 11, 2006 | Hotpoint HSS25GFP Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
925 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
