Question about Acer Aspire 3000 Notebook
My computer does not recognize the dvd/cd driver nor does the tray open without using the reset
  • 1 more comment
  • qsbarr Dec 01, 2008
    Hey Mr. Farl;
    The DVD/CD no longer appears in the Device Manager:(.
    We used the info from support.microsoft.com/kb/929461/en-us and followed necessary prompts.
    Still does not work.
  • qsbarr Dec 04, 2008
    Hey Timothy,
    Thank you. Please give me and my Hubby some time to review and process and work on it. We will return.
    Meanwhile,
    MERRY CHRSTMAS:)
  • qsbarr Dec 19, 2008
    Hey Timothy,
    We have not had the opportunity to work on our Acer - Vista Windows. Christmas, work, weather, life, etc.
    I am looking forward to trying your suggestions.
    Merry Christmas to you and your family.
    Sergeant:
    Novelist:
  • 192 Answers
Ok, first things first. When you first turn on your system, you need to open your BIOS. Once you do that that, check to see if your dvd/cd drive is listed. If it is, then it's just a case of getting Windows to identfy, if it's not listed in your BIOS, then it's a hardware fault, as Windows won't identfy anything that's not listed. Let me know either way, as I may have a solution if it just needs to be identified.
Posted on Dec 03, 2008
    Sergeant:
    Novelist:
  • 192 Answers
When you say "dvd/cd driver", are you meaning the dvd/cd rom tray, or the actual system driver?
Posted on Nov 28, 2008
  • 2 more comments
  • Timothy Farley Dec 03, 2008
    Hi again,
    If it is listed in your BIOS, could you let me know what version of Windows you're running.
    Thanks
  • Timothy Farley Dec 04, 2008
    A common misconception is that cd/dvd drives require a driver. They don't, they use "class filter drivers". These add functionality via a burning program, i.e. Nero...
    Class Filter Drivers can only be found with the product i.e. Nero, NOT the drive's manufacturer.
    Firstly, go to the Acer website - Support and Downloads, and click on the link for Driver downloads. Find your system, and locate the Chipset driver for your OS, download, un-zip, and run.
    If you can't find your Chipset driver, as Acer don't provide driver support for all, you can download it from the Chipset manufacturer's website. If I have lost you a bit, the Chipset is usually VIA, INTEL, or SIS.
    Intel have a program that can identify the chipset you have, then you will be able to download the correct chipset drivers.
    Hope this has helped so far
    Ok, I may be getting a bit long winded for you, so please bare with me. I have had a look, and you are using a SiS chipset.
    Please go to http://www.sis.com/support/support_prodi... . This will identify what chipset your running and hopefully you should be able to update them.
    If none of these suggestions work, please let me know
    No problem, you know where to find me. Just hope I have been of help.
    Merry Christmas
CD/DVD burner in Compaq Presario 5010NX w/ VistaBasic Reads and any DVD but has problems with CD's. If I load a music CD, sometimes it will open right up and I can play the music. Most times it just...
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
Mar 14, 2011 | Compaq (CDD480172) CD-RW Burner
3 or 4 times a day my MSI DVD writer/Player will not recognize a disc in the tray. how do I correct this
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or you might try using a different type/brand of cd/dvdrw
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 26, 2010 | MSI (DR12-A) DVD±RW Burner
The cd drive isn't recognized. it was working fine but now it powers up and i can open tray but wen i try to use it the display says no cd drive. i tried another cd writer in it but same prob. help[!!
does it show up in the my computer? what OS you useing i.e XP / VISTA?
sounds like the drivers are missing.What kind of CD you putting in CD or DVD if it's a DVD try a CD & if it plays then the DVD heads have gone it's common for the DVD heads to go before the CD heads.
Sep 28, 2010 | Computers & Internet
Using Windows Vista on Dell Dimension Desktop: Windows Explorer does not show a DVD drive. The eject-close button does not extend or retract the disk tray. I have opened the tray manually with a...
try method 5 listed on this site:
https://support.microsoft.com/en-us/help/314060/your-cd-or-dvd-drive-is-not-recognized-by-windows-or-other-programs
May 22, 2017 | Dell Dimension E521 PC Desktop
MY LG SUPER MULTI GH22NS50 DRIVE IS NOT RECOGNIZE WHERE DO I GET DRIVERS OR HW DO I GO ABOUT SOLVING THIS PROBLEM? IM USING VISTA
Windows 2000 & XP & Vista & 7 all contain the necessary device-driver software for CD/DVD units.
Open "My Computer" -- the device should be listed.
Open "Device Manager" -- the device should be listed.
If not, does the tray open/close when you press the button on the face-plate? If not, there is no electrical power reaching the device.
Check the SATA "power" connector.
Try using a different power-connector from the power-supply to the device.
Sep 15, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Desktop DVD fails to recognize "commercial" DVDs
Hello my friend,i can think only 2 things.The first thing is the region code.So right-click My Computer then select Properties,select the Hardware tab,click the Device Manager button and go to DVD/CD-ROM drives,double click to open the tree.Then choose your dvd burner and double click or right click and properties to open the dvd properties.Go to the dvd region code and select the code/country that the dvd supports and click OK.Also you can download a program called region free.The second thing is that your drive supports CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD+R DL, DVD-R DL, DVD-RAM so if the disc is something else then is not supported by your reader/burner.
Feb 08, 2010 | LG GSA-H55N DVD-RAM Burner
Pioneer dvd r/rw wont play a dvd
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
Mar 19, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Driver
Well If you need a driver because you computer does not have it in it's driver list then visit this link to get the driver http://support.acer-euro.com/drivers/downloads.html
and chose the computer you have choose the driver for you CD/DVD Drive and it should work then, After you download and install the driver unplug the drive then plug back in and it should say found new hardware, the it should say the drive name and alot of different names just click the X for each then you will get one saying you hardware is now installed and ready to use and then it should work.
Feb 17, 2008 | Computers & Internet
Cd not recognized
Often the Laser for the CD section gets burnt out... I have seen this often there is no fix... Ya gonna haveta get a replacement sorry.
Apr 19, 2007 | Lite On (SOHW1633S) DVD±RW Dual Layer...
Acer Aspire 3000 Notebook Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
