Question about Nokia N70 Cellular Phone
DEad phone my phone died one day and i don't know why. i charged it and it still wouldn't turn on. If it turns on only the screen wll light up and do nothing else. no sounds nothing. and then it won't turn off until it runs out of batteries. I don't have much money and the service provider dissconected me. so i want to fix the phone and unlock it for another service. but i need some help
    New Friend:
My nokia n73 device manager is not update
Posted on Mar 30, 2014
  • 107 Answers
This can be done by connecting your phone via a data cable (cost 5pounds max) and downloading nokia pcsuite and software updater. then update the phone which will work. please ensure you have a fully charged battery when doing this or phone will nedd complete reflash and that can cost 25pounds. then purchase a turbo simm and this will allow you to run on different network cost 10 poinds. can be bought from ebay shop
4onesexpress-07802458019
Posted on Nov 29, 2008
Epc light in a 2003 Turbo-S Volkswagen beetle turned on, shut off. Next day car wouldn't turn over. How do I fix this from happening and start the car?
check battery volts should be 12.6 volts.if not battery dead.have battery charged and test if battery can be charged alternator faulty.if battery dead cant be charged replace battery.and clean battery cables if EPC warning light still flash have vechicle code scan for faulty accelerator control system or mass air flow sensor.to get vechicle started after replacing battery just turn ignition switch to the on position for 30 seconds then turn off ignition switch then start engine.
Apr 04, 2013 | Cars & Trucks
A few days ago, the batteries in my Rock Band 2 guitar died so I replaced them with new ones. When I tried to turn the guitar back on it wouldn't work. When I hold down the Xbox button all of the...
Yes, it's called dead batteries.
Replace the batteries with new ones, and then just turn it on. It shouldn't be necessary to sync it to the xbox, unless yuo have synced it to another xbox lately.
Jan 11, 2013 | Video Game Consoles & Games
I purchased the I phone 3 abt a week ago No damages no drops the phone as I was charging it which it had died completely when I tried charging it charged and showed 100 percent charged but the light...
Your cell phone or battery is faulty. I suggest you return the cell phone to the supplier/chop for repair or replacement as it will be under warranty.
Dec 21, 2012 | Cell Phones
Hi, i have a blackberry bold 9000, i went out of town for a day and forgot my charger at home and my phone was running low on battery, later that day it died. When i got home to charge it i would show the...
Dead battery. Try that first.
If that's not the case. the battery contact terminal might be bad. Which is common.
Chances are, it's just a fried battery that needs to be replaced
Sep 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have a wirless xbox 360 headset and it was working about 4 days ago and I had it on charge when it died when I went to charge it wouldn't charge or turn on and I have had it to long to take back to...
so you are saying that you have a chargeable microsoft headset and the last time you tired to charge it. it would not work... it sounds like your rechargeable battery is dead and you might need a new one. also try you head set on a friends unit and see if it works, at the same time take their chargeable battery and place it in your headset and see if it works that will tell you if it is your headset or the battery..
game tag DeepReserve
May 19, 2011 | Microsoft Wireless Headset for Xbox 360
My 88 Tracer started having problems with all dash lights being on. Then a day or two later over heated lost all antifreeze except small amt in overflow. Let it cool added some to radiator and overflow....
OK, first, I think it may be the alternator. If you charge the battery overnight, the engine should run for about an hour before it discharges again.
I don't think the coolant should affect the wiring.
There may be a fuse panel for the high current fuses in the engine compartment. It should be 30 amp or higher.
Does the generator/alternator/battery light come on when the key is in ON position?
What engine? 1.9L or 1.8L?
VIN Number?
May 17, 2011 | 1988 Mercury Tracer
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
