Question about Tappan TGF320 Gas Kitchen Range
HOT oven Range
I have a Tappan gas oven. I have no idea how old it is. The range is so hot. And the oven is not on. I opened the top and there are 2 lights (gas) lit. Is this normal?
    Sergeant:
  • 229 Answers
Yes those are pilot lights and this is perfectly normal in fact only be concerned if they are not lit. This is just a fact of life with gas ovens. Little bit spooky huh? That's why I have always preferred electric ranges but gas is preferred by many.
Posted on Nov 28, 2008
I have a tappan gas stove. the stove top works but the oven doesn't heat up enough to cook and i can smell gas. I checked the gas line and it is tight with no leaks. i am wondering what could it be and...
You could do the repair yourself. Much more information is needed. Is your oven spark ignition or hot surface ignition ? A valve may be opening only partially. This can happen on a hot surface ignition system when the glow bar is starting to malfunction. Need to know more details to be of real help.
Tom
Aug 10, 2010 | Tappan TGFS26C Gas Kitchen Range
Oven ignitor
is the ignitor getting white hot in the center.it may not be drawing enough current to open the gas flow regulator.the only othe thing foe you to replace is the main control board.or better known as the clock timer
Jun 09, 2010 | Tappan TGF351ES Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Self light oven not lighting - gas fills the room
its the hot surface igntior that glows could be cracked might need replacing
When using oven. glow plug gets red hot,but only a small amount of gas comes out. not enough to lite oven
This will sound really crazy, but the problem is the glow plug or ignitor. For the gas valve to open it needs to pull X numbers of amps. After they get old they do not pull the required amperage to open the gas valve. This safety feature can be very confusing.
Checkout this tip it will give you a better idea of what is happening.
At the bottom of that tip is another on how to buy parts online.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Jan 27, 2010 | Tappan 24 in. Freestanding Gas Range...
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan - Model 36-3052-23
I suspect you may have a bad igniter. They will still glow nice and hot, but if they are weak the gas valve will not open. This is actually a safety feature. Depending on which type you have, the glow bar igniter is supposed to draw a certain current potential before the gas valve will open. Here's the current readings for both types: Round Glow Bar: 2.7 to 3.2 amps Square Glow Bar: 3.2 to 3.7 amps I would try to to determine if the igniter is good or bad before proceeding with a gas valve replacement. Generally, the igniter is a common fail item. Let me know if this helps.
Sep 06, 2007 | Tappan MGF500PBW Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
111 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
