Should i run series or parrellell should i set my subs at 2 or 4 ohms
SOURCE: what is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
SOURCE: car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
SOURCE: amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
SOURCE: SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
SOURCE: Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
