Question about DeLonghi DC60T Coffee Maker
Coffee Maker goes off during brewing
Coffee starts to brew but then the power goes off. I unplug it and sometimes it goes back on and other times not until the next day. Is it time for a new one? I have hard water where I live, could this be causing the problem? Now today it brewed just fine and the power is still on 10 minutes later. HELP!
  • 619 Answers
SOURCE: Coffee Temperature
Hi , if you could open the below cover check the heating sensor might lose connection / if their is possibility to unscrew the sensor try to applied heat sink grease available in appliances repair shop , make clearance to boiling tank thick two papers in applying sink grease,same in warming surface.
Posted on Jan 21, 2008
SOURCE: My DeLonghi DCM485 coffee maker
The same thing happened to me....At least you got three years out of yours, I got three months.
Posted on Sep 11, 2008
SOURCE: Coffee won't brew
Tossed the coffee pot and bought a new one.
Posted on Sep 10, 2009
SOURCE: wont heat or brew!!
Make sure the coffee maker is unplugged there's 120 lethal volts inside when plugged in!
This unit has a replacable thermal fuse. It's a "Microtemp" Thermal Cutoff Fuse G4A00. You can buy five on eBay for $2.70. There are two on this unit and they are in the base concealed inside a 3" white mesh that runs alongside the heater. You will need a security fladebladed screwdriver that you can make by filing a notch in the center of a regular screwdriver.
Posted on Nov 26, 2009
1800PartsFix
  • 36 Answers
SOURCE: Have a delonghi dc78tc coffee maker and have power
Try replacing the element. What is happening is is that the element is not getting hot enough to pull any water from the tank and heat it and send it up through the shower head to brew the coffee. Sometimes it can be a thermostat but more than likely it is a heating element.
Posted on Oct 28, 2010
Having trouble programming my grind and brew coffee maker. Did not come on at specified time
Sometimes these machines get "confused" as it were. Try unplugging it from the mains, wait about an hour or two, plug it in again, reset the clock and the timer...
Jul 17, 2014 | Cuisinart DGB900BCU Grind and Brew 12Cup...
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
My power company shut my power off during the night and the next morning my $100. Cuisinart Grind and Brew 10 cup Coffee Maker- Black, serial #40219C would not work. Is there any hope for me.
what exactly is it doing or not doing ??? any lights come on when you attempt to use it. chances are it just needs to be reset (unplug it for about ten minutes then plug it back in).
Robert
Sep 22, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker shuts off during brew cycle
I to have been battling this same problem on and off for a couple of years, and have been trying to find out why it thinks it id done brewing. I have had some success but exactly what fixes it I don't know.
I called Cuisinart and they told me to change the water filter in it. This didn't work, but I did see some grounds and even a bean had gotten under the filter. I cleaned that out and it fixed it, that time. If you don't have a filter, shine a light down the water reservoir and make sure you don't see anything.
Other than that I do a bunch of cleaning cycles with, Brew Rite Cleaner, Whink Automatic Drip Coffeemaker Cleaner, and vinegar. Don't mix them, just follow the directions on each. Follow with a bunch of rinse cycles. I still don't know which one does the most to fix the problem. For all I know it could just be all of the rinse cycles.
Just keep trying, there is hope that you won't have to tend to your coffee maker forever.
Nov 29, 2007 | Cuisinart DCC-1200 Coffee Maker
DeLonghi DC60T Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
