Question about LG RU-44SZ63D Television
LG RU44SZ63D click to turn on & it acts like it will but doesn't.
When I Click to turn the TV on the light blinks like it's going to turn on then it doesn't and the light turns red again. What could be causing this?
  • Jim Pope Dec 02, 2008
    I have the same problem that just came up. Mine is over two years old. Have you had any luck finding a solution?
  • Anonymous Jan 03, 2009
    same problem but I dont know where the bulb is??? Can you help please???
    Problem Solver:
  • 3 Answers
Sounds like you need a new lamp. Just replaced mine
Posted on Jan 01, 2009
Yes...replaced lamp and works great.
Posted on Jan 02, 2009
Tip
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen. The password is 8741.
Expert mode allows the normal parameter changes as well as screen size and position, and RGB offset/gain control, for every input.
on Dec 07, 2009 | Televison & Video
I try to turn on the TV and the power light keep blinking but it doesn't turn on, the screen remain black...
The set has a problem that is likely power related===consider having a shop or a tech look at it---cannot wish it away, someone will have to open and check things to even have a chance to fix this.
Dec 03, 2012 | LG 37LG30 37 in. LCD HDTV
Pioneer plasma TV. When I power on the red power turns blue, as it should. But then I hear a second "click" and the actual tv never powers up. The blue light will then blink thirteen times over and
if you know electronic repair, what you can do is trouble shooting. you will need to check weather the output voltages from the power supply going to the sustain board doesn't drop or need adjustment.
Oct 28, 2012 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Blue Blinking power light
This sounds like a known issue for this TV. LG has a service bullentin #0IVL20090710 regarding this issue.
Try calling LG and let them know about your TV having the know issue and the service bullentin 0IVL20090710. They should fix your TV under a warranty. So be nice when you call to schedule your in home warranty.
LG 800-243-0000
Good luck. I do hope I have helped you.
Jun 27, 2010 | LG 32LG30 32 in. LCD HDTV
LG RU-44SZ63D turned off while watching, heard click noise
Problem is either you need to replace Lamp or your Lamp Fan is defective. For Lamp Call Mats 1-800-68-1118
May 13, 2010 | LG RU-44SZ51D 44" Rear Projection...
Lg tv problems ru44sz63d It turns on to a
http://www.retrevo.com/support/LG-RU-44SZ63D-TVs-manual/id/371ci555/t/2/
http://www.eserviceinfo.com/index.php?what=search2&searchstring=J52A+(projection)
Above are links for your service manual, and a training manual. This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
May 13, 2010 | LG RU-44SZ63D Television
Plasma TV will not turn on
The 7 blinks means that the SC scan drive board might need to be replace but only after checking the voltages from the power supply. If the voltages from the power supply are normal, then proceed to replace the SC scan board.
Click here to find the board you need.
Dec 20, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Lg 50px4d-eb
I have one here next to me when I pushed power the green LED started blinking until it brought up the picture 1 blink per second about 8 blinks. i am on the tuner input it may vary on different inputs also if it blinking like 1 blink pause 4 blinks or some pattern like that that is tech diagnostic error codes. if the tv is working you should be able to get a menu or on screen display even without an input attached. Also I only heard 1 relay click in the back
Jan 19, 2008 | LG 50PX4DR 50 in. Plasma TV
LG RU-44SZ63D Television Logo
498 people viewed this question
Computer Repairing
Computer Repairing
