Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet that flashes f2 and will not do anything, it freezes up and locks up
  • jaker_999 Nov 29, 2008
    i did this and it still does it. i cleaned tube from back of washer to sink. dont know waht to do
  • 116 Answers
CLEAN OR REPLACE PUMP F-2 PUMPERROR CODE OR LONG DRAIN ,,,,,,,,,,SHOULD SOLVE PROBLEM
Posted on Nov 30, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
F2 is an indication of long drain, id try to remove hte lower access panel (3) screws across the bottom front of unit, youll see a filter clean out ( large off-white turnscrew) unscrew snd remove debris from area. be warned there will be water inside hte filter when unscrewed, so UNPLUG UNIT FIRST!!!!!!!!!! and grab some towels first
Posted on Nov 29, 2008
F2 PROBLEM
in google search bar ,type (whirlpool ghw 9400 duet fault codes),
then clic on (whirlpool duet intro)
(https//secured whirlpool.co.service) this should give you a good description of the machine
Jul 30, 2011 | Whirlpool GHW9400 Duet Washer
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
My duet dryer says control locked any idea what to
The following link explains how to correct a Control Lock problem on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct the problem, please let me know. I hope this helps.
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer need to be repaired
The f2 code is a pump problem. Need to look in pump. It is the first cycle to be satisfied when started.
Oct 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal De
