Question about Microwave Ovens
Keys on the GE microwave are not working
GE Model LVM1750SM1SS - Some keys on the ket pad are not working.
  • springirthdo Nov 28, 2008
    my goldstar key pad quit working a week after warranty was up now the only numbers that work are 1, 2, 3, 7,8,9, start & cancel???
  • Anonymous Mar 18, 2014
    KEY PAD DOESN'T WORK r-3A85 MICROWAVE
  • Microwave Ovens Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't fix it, you have a failing keypad.
That part is not available separately, so you would have to order the control panel assembly, which includes the plastic frame with the keypad already mounted on it.
While GE charges $175.25 for this, you can get it for only $109.26 here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
keys on the GE microwave are not working - moz-screenshot.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Dec 02, 2008
How to fix key pad on ge convection oven jvm1790bk. Pad stopped working
The control panel is actually 2 different parts and either could be bad. Do you have the display still lighting up or is it completely dead? If it is out it could the main smart board. If it still lights but no buttons work then it could still be the smart board or just the key pads which are a separate part. Neither part can be fixed just replaced.
Feb 26, 2015 | GE JVM1790 Convection / Microwave Oven
Frigidaire troubleshooting key pad seems to be stuck on child lock
If you have your owner's manual, read the section on how to disable the child lock. If that doesn't work the touchpad could be defective.
Jul 17, 2014 | GE SpaceMaker Microwave Ovens
GE lvm1750sm1ss
May be a defective or loose ribbon connector on the control board.
Nov 26, 2017 | Microwave Ovens
I have GE microwave oven model JVM1740DM1WW-1000W. the key pad 1 to 6 on express is not working. all other key pad works. how to troubleshoot this problem?
you can try removing the outer cover and being careful,check all ribbon cables to the keypad by removing if they are plugged in and not soldered to the keypad circuit board and re plugging them back in,if this doesnt solve the problem you will need to replace the keypad board
Aug 07, 2011 | GE Spacemaker JVM1740 Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Stirrer Motor Part Number PS237771 GE Microwave
Quite possibly the Stirrer/ antenna motor. To Replace that, the outer cover of the machine must be removed. Unplug unit and take off the screws on the back of the unit and pull the cover back toward you and it will come off. The antenna motor is on the top of the unit and is only held on with 2 screws. You take off the two screws and lift it off of the unit. when replacing it you have to make sure the antenna is properly positioned on the shaft of the new motor to make sure it will turn properly. Not a difficult repair.
Oct 30, 2017 | GE Microwave Ovens
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Key pad stop working
HI. this will happen over time if the microwave is used heavily and if it is over three years old. this key pad is attached to a smart board that you will need to replace. replacing the smart board will fix this issue.
Jun 06, 2009 | GE Microwave Ovens
Microwave Ovens Logo
433 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
