Kenwood Receiver KR-a5020 receiver won't come out of standby
When you push the power button, you here a click and the unit/display lights up like normal but the second power on click does not occur. Before it was broken the following would occur:
1. A click is heard and the unit lights up
2. After a one or two second delay the unit would click again and the unit would play the input.
Step number two doesn't happen now.
I check all the speaker wires and speaker on/off button and even tried using headphones and still no sound. Is there any fuses that could be blown or a bad relay of some sort that is preventing a full power on?
  • zylaos Nov 29, 2008
    Thanks for the tip. I did notice some capacitor leakage on the circuit board that corroded some resistors.
    Thanks again!
  • 4,234 Answers
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
KR-V6050 I cannot get audio to work on radio, video or any other setting. Also the red standby light stays on all the time, even when the power switch is turned off. Alan
Check the input / output connections are in the correct places. The red standby will stay on when the unit is off showing that it is ready for use. To confirm, turn the power off at the wall. The red light should go out after a few seconds.
Nov 20, 2016 | Kenwood Kr-v6050 Audio Video Stereo...
No power
One has to open her up and check for aged or swollen caps on the
power supply.
Sep 08, 2012 | Kenwood Audio Players & Recorders
Hola donde puedo conseguir el manual del receiver
Hola! Puedes buscar un manual por tu radio en el website de Kenwood por supporte.
Solo necesitas a buscar tu numero del modelo de tu radio y puedes copiar el manual ...no cuesta nada... checkas AQUI
May 30, 2010 | Kenwood KAC-9152D Car Audio Amplifier
My Kenwood KR-V5570 receiver powers off when I try to run a medium to high volume and the standby light blinks
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
Apr 27, 2008 | Audio Players & Recorders
Unit fails to power up
bad unit in power take it back if u just got it my fav is harmen kardon and kenwood 7.1 thx good prices too does everting way it should last forever
Jan 19, 2008 | Onkyo TX-SR605 Receiver
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
Jan 18, 2008 | Kenwood VR-606 Receiver
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
Standby mode, shuts off
After 10 years of use probably best to replace with a new unit. Most will be hard to find exactly wich little bit is broke.
May 23, 2017 | Kenwood KR-A5080 Receiver
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
1,147 people viewed this question
 Grubhead
Grubhead
