Question about Lands Phones
Will not clear memory or messages - Lands Phones
  • smiler1661 Nov 28, 2008
    Hi , Tried that and no luck. Its a LG Shine and apparently is a common problem. It will not clear anything out of memory or messages. Now got over 300 messages in storage
  • 19,396 Answers
Try unplugging phone power cord for ten minutyes and removing battery at same time.
Posted on Nov 28, 2008
  • Ginko
    Ginko Nov 28, 2008
    Let me know what kind of phone you have.
    If this is a landline phone system, just unplug all phones and remove handset batteries to reset the phone setting, then perform a complete factory reset and clear memory procedure, it should work.
    If this instead is a mobile:
    Try resetting phone to factory setting with the reset procedure that you find under phone tools menu.
    Extract and check the memory card, ensure that the write protect switch at the side is not on.
    Try a different memory card.
The message memory is clear bt i can't reply massage
Check all your drafts and saved messages. If any clear them. Also clean your outbox or sent items. Change settings from sim storage to phone storage. You can do this by going to message settings > memory in use> and so on.. again depending on your phone.
Jan 17, 2014 | Sony Ericsson TM506 Cell Phone
Omni 3200 "BAD EPROM" message
Can you clear the cmos to defaults? If still there after clearing out, then your cmos has somehow gotten corrupted.
Sep 06, 2017 | VeriFone Used Omni 3200 Vpv50us2 Modem...
My phone keeps saying memory full.. cannot receive any messages or send messages from my cellphone..please assist me..
Hi there, In order to start sending and receiving messages again you're going to need to clear up some memory. To do this, you're going to need to go through your messages first. Clear out all your sent and received text messages. There should be a delete all option, but if there isn't, you may have to do it one by one. Once you've cleared out messages, you may want to look into deleting a lot of pictures as well. Pictures use up memory very quickly. Good luck, Alex
Jun 06, 2011 | Nokia C5 Cell Phone
MEMORY FULL ON SHARP UX-460
In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
Oct 20, 2010 | Office Equipment & Supplies
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Cannot clear memory--NEED FOR WORK ASAP!!!!!!!!!!!
Out of Memory message
If the memory becomes full while you are making copies, the LCD
message will guide you through the next step.
If the Out of Memory message appears, press Stop/Exit to
cancel or Black Start or Color Start to copy the scanned pages.
You will need to clear some jobs from the memory before you can
continue.
To gain extra memory, you can turn off Fax Storage.
—OR—
Print the faxes that are in the memory.
When you get an Out of Memory message, you may be able
to make copies if you first print incoming faxes in the memory to
restore the memory to 100%.
Apr 07, 2009 | Brother MFC 420CN All-In-One InkJet...
Clear All Memory Files
exit "store" mode (if it is in it)
clear display
hold down the Code key and hit the C key
message should come up "CLEAR ALL FILES Y/N?"
hit Y, message should say "ARE YOU SURE Y/N?"
press y again to clear all files
to cancel the memory all clear function, press the N key at the first or secound prompt
Nov 13, 2008 | Nakajima AE-740 Typewriter
Unabel to clear phone memory
Messages can only be stored on the internal memory of the phone and not the memory card.  The memory card is only used for media.
The best way to clear out your messages is to have a data cable or a bluetooth transmitter on you computer and install nokia PC Suite from Nokia.com.  There is a message management program that will allow you to clean up old messages stored in your cell phone.
If that isn't possible to do, the only other choice you have is to manually delete messages from you phone.
Oct 16, 2008 | Nokia N70 Cellular Phone
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Lands Phones Logo
21 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
