Question about Slider Kyocera SE47/ Portable Handsfree Kit Headset
Using Logitech headset & enable Skype to ring via Desktop speakers
Hi, can anyone please help me by explaining which settings I need to enable the following?: To be able to speak & hear via the Logitech headset, but also the desktop speakers to work so that I can hear any Skype calls. The headset did work properly but I changed settings, now DT speakers ring, microphone works but can only hear via DS speakers. Please help??? Lambchop
I am having the same problem. Can anyone help?
Posted on Jan 24, 2008
SOURCE:
I wish to connect it to my laptop its registering and is connect to the bluetooth but when i make a call on skype it dont work as a mcrophone and speaker
Hi!
If you have paired and connected the headset to your computer, then please do the following:
1. Sign in to Skype and in the TOOLS menu, select OPTIONS...
2. Under AUDIO SETTINGS, select your Bluetooth headset from the MICROPHONE, SPEAKERS and RINGING drop-down list.
Please let me know if it helped.
Best regards
Aug 09, 2011 | Motorola Mobility H350 Wireless Headset
I have speakers and a logitec headset, they work independantly, but i was wondering if i could get them both to be enabled at the same time, sometimes when my friends are over i need the headset but i hate...
It depends upon your sound card capabilities. If you open the Volume/Audio Mixer via the notifications area, you should be able to call up the settings. Some (not all) cards allow for the simultaneous enabling of both headphones and speakers via a setting in that area. The predominant default, however, is not. The assumption of course is that if you're using the headphones you don't want the speakers.
Hope that's helpful.
Jan 06, 2011 | Logitech Televison & Video
I am getting a large amount of audio feedback (pulsing) when using skype and the logitech C500 webcam. The noise may not occur the first time I connect, but almost always occurs when I reconnect. Shutting...
You do not say if you are using a laptop with built in speakers or desktop with add on speakers. Also no indication of your OS.
I think the first thing you need to try is using a headset to cut out the possibility of 'feedback'
Check out your audio set-up
Typical audio set up
Laptop x webcam/mic x Vista x Skype
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Start Skype.
On the Tools menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Set your speakers as default.
Select your webcam as the default microphone.
Click 'Save'
Dec 20, 2009 | Logitech Quickcam Chat Webcam
Lose webcam connection in Skype when using a headset
Have you checked the recording settings in Windows and in Skype? Try changing the default recording device to specifically indicate the device that has your headset plugged. I think the webcam also has a mic and that should not be selected.
Other thing to check is if there is some kind of resource conflict between your USB controller and audio card (use Device Manager).
Jules
Mar 02, 2009 | Logitech Quickcam Chat Webcam
Hi, I purchased a logitech stereo headset with noise-cancelling microphone, sent to my sister overseas to use via Skype or Majic Jack but when were are talking with each other the noise in the background...
Download audio codec for that. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
Unplug your headset jack. Try rebooting your computer. Replug your headset jack.
Best regards
Jan 10, 2009 | Logitech Digital USB Desktop Voice Chat...
Logitech Microphone Not working
Hi, I have a skype approved logitech headset. I can hear sound, but I cannot record sound or communicate on it. I cannot even find the headset as option as Preffered Device in Sound and Multimedia. I am using Windowsxp
z. Please help.
Feb 21, 2008 | Logitech (980174) Headset
No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
Nov 10, 2007 | Logitech 250 Headset
Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Radio Communications Logo
333 people viewed this question
Top Slider Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Slider Radio Communication Expert? Answer questions, earn points and help others
