How difficullt is it to replace a dc jack in a gateway computer
  • 4,338 Answers
If this is the first time, it can be a daunting task. But it is doable.
Here is a site with general instructions,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
you may even find your laptop listed on this link
http://www.laptoprepair101.com/laptop/category/laptop-service-manual/
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 28, 2008
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Where can i buy a gateway m 7818u charging port?
The proper name is DC Power Jack. May be marked as DC_IN on the laptop.
Just from a quick search,
http://www.aliexpress.com/product-fm/406129021-Free-shipping-DC-Power-Supply-Jack-For-Gateway-MD7818U-MD7822-MD7818-Acer-Aspire-5532-5535-ONE-wholesalers.html
(First one I saw was $59)
Need guidance in replacing? Post back in a Comment.
Regards,
joecoolvette
Jul 21, 2012 | Gateway M-7818u 15.4" Notebook PC - Avalon...
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
If I need to repair or replace my gateway mx6448 motherboard, which is most cost-efficient: to repair or replace? How would I know the difference? I am not an expert, but can I do this repair or...
Depends on what is wrong. Is it the DC Power Jack? The jack you plug the AC adapter (Charger) into?
Average cost is around $100 for a DC Power Jack replacement. (It's labor intensive, but the jack itself usually runs around $8 to $14 )
Most computer 'repair' shops do not have the skills required to perform this procedure.
The easy way is to just replace the motherboard. (Also more Ka-ching in the pocket)
Just a typical DC Power Jack replacement,
Disassembling a Gateway MX 6000 series laptop,
http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
Some designs of the motherboard, have the DC Power Jack mounted in an area on the motherboard, that DC Power Jack failure is a reoccurring failure.
The motherboard cracks in the area the DC Power Jack is mounted. (Breaking the circuit traces)
In this instance it's better to replace the motherboard. Of course it's going to fail later on.
Your question: "Can you replace the motherboard?"
I have confidence in you, I believe you can.
Doesn't take a rocket scientist, but does require patience.
1) Remove ALL Power to the laptop. AC adapter (Charger), and Battery.
2) It would behoove you to buy, and wear an ESD wrist strap. (Electro Static Discharge)
Connect the alligator clip to a good ground source.
I connect to the metal frame of an empty desktop computer case.
(Average cost is around $3 to $8. Look online for reference. Visit computer repair shops, and stores like Radio Shack for purchase)
Your body carries Static electricity. Static will fry out (Short Circuit) the hardware components inside a computer. Especially a Processor.
With wearing an ESD wrist strap, and connecting to a good ground source, your laptop is safe.
3) There may be as many as 60+ screws. There may be 12, or more different types of screws. DO NOT mix them up! Use a multi-compartment container, and label the compartments for the area the screws came out of.
You can use a clean egg container, (Or two) in a pinch. label each egg holder.
4) You may want to take photos, and make notes as you disassemble. Makes a real handy guide for reassembling. Also nice to have if you get interrupted in the middle.
Obtaining a motherboard:
You might check Ebay. Sounds like advertising, but it isn't. Just one of my sources.
Also check Laptops for Parts on Ebay.
Some sell a laptop that has a broken LCD screen as the only fault.
Post questions in a Comment.
This is what the motherboard looks like, (Gateway Support),
http://support.gateway.com/s/Mobile/Q106/BladeK8F/4001199R/4001199Rmv.shtml
Oct 13, 2010 | Gateway Computers & Internet
Gateway MX6956 screen flashes when dc adapter plugged in...hard t
The jack is soldered to the mo bo. If that is the only thing wrong all you have to do is open up the unit carefully, get access to the mo bo, resolder it and reassemble everything. A real PIA job but do able. Good luck
Sep 18, 2017 | Gateway MX6956 Notebook
No connection with the DC Jack on Gateway 3550GZ
It's time to take the computer to a qualified technician, for proper trouble-shooting & repair, because there are very-few "user-repairable" parts inside a laptop/notebook computer.
Jan 20, 2010 | Gateway 3550GZ Notebook
NEED TO REPLACE THE dc CONNECTOR ON A MA7 GATEWAY LAPTOP
You will need to First Order/Receive a New Replacement DC Jack...
Then The Laptop Needs To Be Disassembled Down To The Motherboard.. let me know if you need full instructions on the steps involved in the DC Jack Repair..
Nov 24, 2009 | Gateway Computers & Internet
MY GATEWAY LAPTOP NO LONGER RECEIVES POWER.
Motherboard or harddrive? I'm betting it's more towards the motherboard. The DC Power Jack to be more specific. This is the port where the AC adapter, (Charger), plug is plugged into.
The DC Power Jack is not much bigger, than the plug for the AC adapter that plugs into it. There are small pin leads that are on the bottom of this jack, and they go through the motherboard, and are soldered to the motherboard.
Accidental bumping of the AC adapter plug, while plugged into the DC Power Jack, can damage the jack. It can break the connections for the adapter plug, and/or can crack the solder joints for those small pin leads.
[Laptops use DC electricity. A flashlight battery, and a laptop battery, are examples of stored DC electricity. DC electricity has two poles. Positive and Negative. The DC Power Jack has two connections. Positive and Negative. {Even if the DC Power Jack has multiple holes in it]
There is also another known problem associated with DC Power Jacks. It may stem from a bad motherboard design.
More to the point, the area where the DC Power Jack mounts on the motherboard. In this design, the DC Power Jack motherboard area, is almost a separate part of the motherboard. It's shaped like a Peninsula. (Think of an island, with one side connected to the mainland)
This peninsula shape, has the tendency to crack away from the main body of the motherboard. Circuit traces are broken.
When the AC adapter plug is setting in a certain position, it presses the two broken halves of the circuit traces together, for a momentary contact. As the AC adapter plug is moved from this position, the circuit trace halves are moved apart, and there is no contact.
(No distribution of electricity from one circuit trace half, to the other circuit trace half. Think of a circuit trace as a very, thin, flat copper wire. When a circuit trace is broken, there is essentially a wire that is broken into two parts)
Solution?
See if the DC Power Jack can be repaired, (Solder joint connections re-soldered), or replaced.
If the DC Power Jack motherboard area is the aforementioned peninsula shape, it may require replacement of the motherboard.
There are very FEW, computer repair shops that have the technical expertise to replace a DC Power Jack. Easy fix is to simply replace the motherboard. (More $$$$$ too)
However, some laptops DO require replacement of the motherboard for this repair.
Bad motherboard design, for the DC Power Jack area on the motherboard.
Re-solder DC Power Jack solder joints? (IF, this is the problem) Average is $50 to $75 (US)
Replace DC Power Jack? Average is $125 to $150. (US)
Replace motherboard? Depends on the Gateway model. Could be $225 to $400 (US)
[Yes, most of the time the cost warrants just replacing the laptop itself, as the cost of replacing, is close to the repair cost)
Just to SHOW you ab average DC Power Jack, and the repair involved of replacing. (Doesn't show you, that the entire laptop needs to be disassembled, down to the bare motherboard in hand)
This is NOT a recommendation to replace the DC Power Jack yourself! It is just for knowledge of what is partially involved. (You can accidentally burn the motherboard when desoldering, or soldering, rendering the motherboard useless)
Sep 09, 2009 | Computers & Internet
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
How do I fix a faulty DC In port connector in my Gateway laptop?
To fix it yourself you would have to take the laptop apart and remove the motherboard.
Repair costs could run you $50 and up depending where you take it.
Example Site
Jun 04, 2008 | Gateway MX6438 Notebook
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
