Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Wii connection when we connect the wii to tv, we hear sound but no picture on channel 2, which is where the games usually work.  The picture connection seems to be off, or not working
  • Sony Master
  • 4,806 Answers
Just go into Input assignment menu and click YES to game, then hit the device menu, the game option should show up
regards
Posted on Nov 28, 2008
  • Sony Master
  • 19,396 Answers
Try a replacement cable, check also that the TV input is set on the right channel.
  • Ginko
    Ginko Nov 28, 2008
    If you are getting sound, then the input channel should be OK, try giving a full round of your TV input channels , just in case.
    The problem looks more like being caused by a bad cable or connection.
    Check the cables at the back of the TV, if you cannot fix this by moving the cable , get a replacement cable.
    If you get the same problem and does not depend on the cable, then the Wii video adapter circuit is faulty, in this case call the Nintendo service number listed on the owner manual to get the console fixed or replaced.
I can hear sound but not picture for wii
Try connecting another cable or connecting it to another TV, else you can get it repaired
Jan 06, 2013 | Nintendo Wii Console
I bought Super Mario Bros. 3 from the Wii Shop Channel, but when I attempt the play the game the screen just goes black and all that's left are the words "invalid format." Also, the TV is an...
Hello.
Here is what it says in Nintendo Wii SHop:
Some newer-model televisions may have difficulty properly displaying some Virtual Console games downloaded from the Wii Shop Channel. If you are experiencing problems (such as a blank screen but you can hear the game's audio), please try the following:
    Try changing the way your Wii console is connected to your television. For instance:
    • If the Wii console is connected to a VCR or cable box, try connecting the Wii directly to the TV (how to).
    • If the Wii console is connected to the TV directly, try connecting it to a VCR (how to).
    • If possible, try connecting to another TV.
    If any of the above are successful, it is recommended you use the connection that works. If the Virtual Console game still did not display properly after trying different connection types, please call 1-800-255-3700 to discuss available options.
Aug 03, 2011 | Nintendo Wii Console
My wii comes on and you can hear the sounds but no picture and i have it all hooked up to the right things but still no pic.help
Hello.
Are you using RCA to connect it (red, yellow, white wires)? Try another port on your TV. The video slot of your TV might be malfunctioning. Depending on your TV, they usually have ports infront and at the back.
Jul 15, 2011 | Nintendo Wii Console
Need to get sound for wii w/ sony bravia tv and sound system
There is usualy a 2nd channel for games like example - video 1 is video games but hear the tv, video 2 is videogames and hear Wii. Hope it helps
Nov 29, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
You can hear the wii menu music, but there is no picture.
reseat the cables onto the Wii and also your TV. Make sure the Video and audio are connect to the audio and video input on your tv. Also make sure that you are using the correct channel, if your using video 1,2, or 3 that your tv is set to the correct one on screen.
If you still dont get video then try another set of AV cables. If that still doesn't work then the mainboard inside of the Wii is bad and would need to be replaced.
Nov 26, 2009 | Nintendo Wii Console
There is power to the console. We can hear the
Check the input cables coming from the Wii to the TV. Then check to see that your selecting that right Aux channel. On most remotes there is a source or input selection. Pressing this should cycle through all input channel selections. One input should be the Wii signal.
Bret
1-2-1ComputerServices
Oct 06, 2009 | Nintendo Wii Console
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Nintendo Wii box light is on but no picture or sound from my tv
sometimes just sometimes tvs are funny, some tv's call it a "input select" others call it a "mode" or simply "input" and some dont have any they just want you to goto channel 2 on the tv and go back one more channel.
ushally all these modes are listed on the remote.
is it the origional remote? or is it a universal remote.
try those things above look over the remote again see if anything resembles any of that and if not
list the make and model of your tv and if your using a universal remote we will be able to figure something out for you.
Aug 12, 2008 | Nintendo Wii Console
Sound
Hi, your wii should provide sound through the Tv as well as the wii remotes, All you need connected should be the skart cable connected to the tv to provide the picture & sound.
i would suggest you contact the company you purchased the wii, due to its still under warrenty. i currently have 2 with no problems and didnt need to change any settings
have a good new year
john
Dec 31, 2007 | Nintendo Wii Console
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
