Question about Sony Cyber-shot DSC-W70 Digital Camera
Sony w70 camera not working,flash error showing thatE:91:0
  • Sony Master
  • 586 Answers
    The flash unit assy need to be replaced.Also E:91:0 is for flash unit purpose which means that flash unit get malfunctioning.
For this you have to contact any nearest sony service centre.
Thanks for using fixya, and dont forget to rate.
Posted on Nov 28, 2008
Go to
setting
main setting
initialze
reset the original default setting
Posted on Dec 10, 2008
I HAVE A SONY CYBER SHOT DCS W210 WHIT ERROR E:91:01 IN DISPLAY TANK YOU hOLA TENGO UNA CAMARA SONY CYBER SHOT DCS W210 CON EL ERROR E:91:01 HAY ALGUNA FORMA DE SOLUCIONARLO? GRACIAS
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Aug 18, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Error 91:01
This Error shows when the problem occurs in flash unit, and the solution is to replace the FLASH UNIT having part No.Description and pic below:
A-1182-558-A ST-133 BOARD, COMPLETE
8f91b54.jpgTHANKS
Jan 19, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Hi I have a sony DSC-W70 Cyber Shot 7.2 and i need to reset it sue to it having a reacurring E with a number on it when you turn it on and the flash is not working can please help me out ?
Turn camera on...Press [MENU] - [SETUP] scroll down [SETUP ] then select [INITIALISE]
Repeat a few times if it does not clear.
What is is flashing error code your are getting is is [E:91:00]
If so flash unit will require replacing. If you are in the UK I can help you out.
p.m at kiddo242@hotmail.com
Aug 15, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My sony cyber-shot DSC-W70 is flashing an error code, 91:01, how can i fix it?
Click Menu
go to setup
then go to setup 1
and go to initialize
then click ok and then ok again
put in the right date and time then
click ok
That should fix your problem! ;)
Jul 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony digital camera is not working properly.y
Nov 28, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70...
It's a flash error, something has malfunctioned with your flash and the system board will continue to give this error until reset by service technician
Feb 27, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Flashing error signal
Seems in a drop or knock flash board might touch metal and short out. When camera gets that error usually the main system board needs to be reset and it seems only trained service technicians have access to tools required to do this
Feb 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
E-91-01 error
Check out the Sony support site.
This is I think a known fault and if it is- the camera will be replaced if it is not a repair price may be quoted.
This price may not be very cheap in which case it would be economic to simply discard the camera and start over
Oct 29, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
109 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
