Question about LG GCE 8240B CD-RW Burner
CD ROM not Detected
My CDROM GCR-8525B cannot detect on both IDE sockets.I think this problem is due to installing wrong FRIMWARE. What could i do to solve this problem.My OS is WinXP. Plz help me???????
    Master:
  • 461 Answers
Is the Drive detected in the BIOS? Can you boot from your XP or any bootable disc? If so try this solution:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Posted on Dec 06, 2008
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
The CD-ROM (Drive:G)
First check it is detected in bios,if not check the power and data cables to the cd rom from motherboard.If its ok,this is a driver problem.I Think the vendor has given you  a cdrom nero.First boot from a windows 98 cdrom,after that put the nero cd .You can find one folder "driver" or "cdrom",change into the directory and install.Reboot your system it will be okay.
Nov 26, 2008 | Microsoft Computers & Internet
DVD +R
Right Click My Computer
Click properties
Find and click the hardware Tab
Click The Device Manager Button
This will bring up the device manager in a new window , from here locate your DVD Drive under : DVD/CD ROM Drives
Click the plus sign next to it and the installed CD / DVD Devices will be shown
To uninstall the CD / DVD Rom Right click on it and choose uninstall
To Reinstall Reboot , and Windows Will Automatically Detect The CD-Rom Drive and install it for you
Aug 25, 2008 | Toshiba Satellite A135-S4527 Notebook
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
LG CD ROM's
Hi, Why do you want to do this? There may be a different solution possible.
Nov 01, 2007 | LG (GCE-8525BI) (GCE-8526BI) CD-RW Burner
Connection Problems
If you have other Optical Drive in your computer like a CDwriter then installed it where that LG 52x CDROM drive. Observe if the same problem occur after 2 or 3 hours. Try connecting the CDROM drive to the IDE ports (Secondary IDE port) like setting its jumper to Master. Ensure that the connection to its power supply is firm. Change the setting of your POWER OPTIONS which is under the CONTROL PANEL and change the setting for TURN-OFF HARD DISK to NEVER.
Apr 08, 2007 | LG (GCR-8523BB) Internal 52x CD-ROM Drive
My cd rom is not shown/detected by my computer. The computer says no cd rom connected,but all the connections are intact,
Have you set the jumpers at the back of the cdrom to slave if you already have another peice of hardware on the same idr cable, if not and only the cdrom is in the ide cable it should be set to master. Also check the bios to see if it is recognised, press F2 or DEL on start up and see if it's there under standard bios settings.
Feb 03, 2007 | AOpen CD 952E Internal 52x CD-ROM Drive
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
LG GCE 8240B CD-RW Burner Logo
225 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
