Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
I have my dozer blade on the tractor but it won't lift up or down and i can't figure it out
  • 2 more comments
  • Anonymous Dec 28, 2008
    installing snow blade on tractor
  • Anonymous Apr 22, 2009
    poop stains
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    is it electric or hydraulic lift?
  • Anonymous Mar 23, 2014
    i would like to install on my tractor but i cannot find a manual anywhere
  • 110 Answers
How are the Hyd line attached?
must get right hoses in inlet and outlet.
Is tractor hydrostatic or Geared?
Posted on Jul 02, 2009
A sears dozer blade will not sit level.one side is an inch higher then the other on a level surface. was originally like this but has gotten worse
It does sound like you have a bent frame. It can also be soft tires on one side of the tractor. You can try putting a block under the lower end of the blade (while still attached) and push down on the the higher end of the blade to spring things back in shape.
Feb 17, 2015 | Sears Garden
Blade will not lift..
Make sure that all the pivot points are greased or oiled sufficiently and not rusted. Also make sure that the pivot points are not to tight and binding. If so loosen a little they should have cup washers on them or nuts with plastic inside them so they will hold the joint but not fall off. Good Luck...
Oct 02, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
My Craftsman 26" 9HP snowblower pulls to the left. Any ideas?
You likely have it in one wheel drive,try lifting the rear wheals of the ground to check and see if both wheels tirn at the same speed.If they don't then you need to change the wheel that is not turning into a drive wheel by removing the pin and putting it back in in the lock position[usually the next hole back in the axle].
Jan 07, 2010 | Craftsman 16" High Garden Tractor Snow and...
How do you install blade on 12hp LT model no.917.254241
what model blade do u have? can you email a copy of the installation intructions?
Nov 24, 2009 | Craftsman 16" High Garden Tractor Snow and...
I bought this dozer blade uses and cant figure out how to attach it to my tractor. Is there a mounting bracket that bolts onto the tractor? Are there any pictures of this or an installation manual with a...
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Nov 16, 2009 | Craftsman 16" High Garden Tractor Snow and...
We are trying to figure out how to assemble our 42" sears craftsman snow plow.
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of your blade and you will see a parts diagram of it.
Dec 21, 2008 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
311 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
