Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Machine bangs and jumps all over as soon as the drum starts moves
Hotpoint aquarius extra washer dryer, model wd64
It has for some time banged and jumped at the start of the spin but then settled down and carried on ok. but now at the start of the wash as soon as the drum starts to turn the whole thing bangs and jumps all over literally moving the machine then it stops and sits for some time before trying again.
I dont think it is bearings, it seems as though the whole thing is jumping.
could it maybe be the suspension rods?
  • twoplus4 Nov 28, 2008
    the belt seems tight and firm, cant find any pay there, it still seems like the whole thing is moving all at once, I can rock it side to side or up and down quite easily
  • Anonymous Mar 15, 2014
    When start machine it jumps and bangs when the boal trys to turn . This happens even when the machine is emtey
    Sergeant:
  • 229 Answers
It is the pulley shaft that has worn out more than likely. Remove the back cover and give the belt a tug or two if there is ANY play at all the shaft has gotten worn on the pulley assy. If it were the bearings I would be surprised as they don't go out nearly as often as the pulley. New pulley and belt should lengthen the life of the appliance considerably. Good Luck
Posted on Nov 28, 2008
I may be way off beam here, but could it be what we suffered from, when we failed to take out the long bolts which prevent excessive movement of the drum during transport? When the spin cycle started the whole machine went beserk, rocking and banging all over the place. This happened a couple of times before we finally twigged and removed the bolts. All OK now. Thankfully no lasting damage.
Peter
Posted on Apr 22, 2009
Tip
Rattle or leaking condensor on Hotpoint WD64
This website has been good to me so I thought I'd post back!
A common problem with the WD64 washer dryer is the condensor working itself loose from the heater box on the top of the machine. This will result in terrifying banging on spin and, if left, screws and rubber seals appearing under the machine. If left longer, as it was with my own, the machine will leak from the condensor to backplate joint at the back of the machine.
The problem is caused by poor fixings at the condensor (the white plastic piece) to the heater (the silver box at the top of the machine).The solution is to remove the condensor, clean it and refit it with new more robust fixings. Hotpoint provide their workmen with a kit of heavy duty bolts, but I did it with a few loose bolts I had. Save all rubber parts as they are riduculously expensive to buy. I had to by the o-ring from condensor to drum backplate and could only get 5 at silly money. If anybody wants one at a good price I'm kolleykibber on ebay.
on Jan 23, 2009 | Hotpoint Aquarius WD63 Front Load...
How do i tighten the drum weights on my hotpoint
Remove rear cover, and you will see the concrete weight at the bottom, sometimes the securing nuts work loose, or break off.
There is also a concete weight in the top of the washer as well,so check this as well
Feb 04, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
237 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
