Question about Panasonic AG-DV2500 DV/Mini DV VCR
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
I use the DV2500 to record videos from minidv tapes on my computer, using QT Pro. I never had problem doing it until recently. What happened is that when I put the tape in the DV2500 and press play, it stopped after only 2-3 seconds. On the screen, I get the message that the recording has stopped because the video has come to its end, which is not true. I believe these tapes (Fujifilm DVM60 60/90) were set up by our camera to record 90 minutes, instead of 60. With another tape deck, I've been able to read these tapes without any problem. And when I use any other tapes with the DV2500, believed to be 60-minutes tapes, everything works fine. My conclusion: the DV2500 has problem with 90-minutes tapes. Is it the case? Thanks.
  • vincentb113 Dec 10, 2008
    Thanks for your comment, it seems to confirm my observations. Do you know if this is written somewhere, like in the owner manual or on Panasonic's website?
    Champion:
  • 221 Answers
The DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Posted on Dec 10, 2008
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
the problem of your player is the mechanism to dv tape slut(not mini dv)...it need to calibrate or to tune up...only can fix this is a qualified technician....
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
WISH TO FIND OUT IF YOU CAN REPAIR MY PANASONIC AG-DVC7 MINI DV COMCORDER. WHEN I TURN IT ON, A MESSAGE APPEARS "THIS CAMERA NEEDS TO BE SERVICED"
I take the cover off the door, using the eraser as the end of a pencil - lightly press on the recording head (drum). Put a tape in and watch to see if the tape now wraps around the head and stays in position to record.
Sep 15, 2011 | Panasonic AG-DVC7 MiniDV Proline Camcorder
I have the panasonic minidv can you record videos without the min
Your Camcorder supports video recording using the Tape only. However, you can record images (only) using the SD Card.
Dec 10, 2009 | Panasonic Video Cameras
Playing DV footage that was recorded on a different camera
Canon camcorders have a non-standard head position. Borrow a panasonic or samsung camcorder (those two are compatible) and backup your casettes on dvds. If you want them to be on minidv readable on canon camcorder, connect it afterwards and send video to minidv through your camcorder. It will then be alligned the way that suites your gear.
Either that or go to the professional service that does conversion from minidv tapes. That usually costs around 15$ per hour, so if you have 10 or more hours of video, the less expensive way is buying an entry model of panasonic camcorder.
Jan 03, 2008 | Video Cameras
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic AG-DV2500 DV/Mini DV VCR Logo
256 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
