Question about Fuji FinePix 1400 Zoom Digital Camera
Over exposed pictures
I have a fuji finepix 1400z that worked fine but now every picture is very over exposed, whited out i guess you could say? any ideas guys tried different cards and its the same thanks
SOURCE: Card not initialized
While the camera is on, press menu and go all the way to the right. Choose "Set-up" and it will take you to a window with several tabs. Choose the tab called "1" and then choose to format the card here.
Posted on Jun 11, 2007
SOURCE: Fuji FinePix 3800 Initialization glitch
Turn camera from "off" to "play" ( photo view..._
Pressing the “MENU/OK” button as you would to erases files. There is an option to format the xD-Picture Card. Formatting erases protected files, but allows you to then take photos.
Posted on Dec 31, 2007
  • 65 Answers
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
Posted on May 28, 2008
SOURCE: card
when I put my card in the camera I get a card error
Posted on Sep 22, 2008
  • 70 Answers
SOURCE: Compact flash card problem
Go to the menu and format the card (as long as it's blank) formatting will erase all data from the card
Posted on Apr 15, 2009
  • 1635 Answers
SOURCE: I cannot format cards in my Fuji S602 zoom.
Make sure your card is compatible for your camera, and or it is not defective. I know that with some camera models the card must meet specific specs. Consult your camera dealer or call Fuji photo support to verify if your card is compatible.
If you have the adabtor for your card to be used directly on your computer, you can see if formating your card with the computer will help. This is not the proper fix, but it may work for you.
Jerry G.
Posted on Jan 23, 2010
0 characters
1 Points
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Pictures with a flash are way overexposed. It just started this so I am sure there is something wrong with the flash. Pictures without a flash are fine
My Fuji has started doing the same thing!
The only way I can get a reasonably exposed photo is to place a piece of white paper in front of the flash to act as a diffuser.
Any info you can find out would be appreciated...even if to know that this is a permanent situation.
Still takes GREAT outdoor and moon shots!
Jul 16, 2010 | Fuji FinePix S5000 Digital Camera
White screen when taking pictures can reveiw all photos taking on all xd cards that I have took pictures on.
But how are the new pictures you take with this camera? If they are white, you probably put the camera intro manual control. Set it back to Auto and it should work fine.
Apr 07, 2010 | Fuji FinePix A500 Digital Camera
My F470 Fuji Fine Pix takes stripey pictures but when it is in movie mode it is fine
Your cameras shutter is sticking. lines on photo's or over exposed photo's are due to the shutter not closing completely over the lens.
Video is fine because it does not use the shutter.
The shutter will require cleaning.
Oct 29, 2009 | Fuji FinePix F470 Digital Camera
My pictures look like I took a picture of a TV
Lines on your pictures are due to the shutter not closing completely. The video should work fine indicating there is no problem with the sensor. Shutter needs cleaning, inspecting for obstruction
Jun 28, 2009 | Fuji FinePix E900 Zoom Digital Camera
Screen white, pcitures white when I take them. Can view stored pictures from card,,,batteries new
call Fuji and tell them that you would like to send in your Finepix to see if the cheap/defective SCR chip was used in your model. If so, they will fix for free.
Apr 26, 2009 | Fuji FinePix Z10fd Digital Camera
Fuji s5000 overexposing pictures
try setting it to auto mode and see if it is ok
they are not over exposed actually they have CCD HR problem ur CCD is having fault as 1000's have the same fault u will get pink shades in white and then later it will stop working u have to arrange for ccd change go to fuji service centre
Feb 19, 2009 | Fuji FinePix S5000 Digital Camera
Flash problem
Same here. Any flash picture comes out nearly bleached out. Started from one picture being fine to the next being white. I'm very frustrated because I love this camera. I have a Digi Rebel and prefer my Fuji 5000! Anyone have any ideas?
Dec 17, 2007 | Fuji FinePix S5000 Digital Camera
Picture is almost completely white...
This is a CCD/processor problem for the still image side. Fuji Technical Help team will advise what your next moves will be.
Jul 09, 2007 | Fuji FinePix S3000 Digital Camera
Overly white pictures
This may be due to jammed iris at fully open. You are over exposing the photographs. if the iris is stucked due to friction a little tappin your camera from side may help you.
Sep 08, 2006 | Samsung Digimax i6 PMP Digital Camera
Fuji FinePix 1400 Zoom Digital Camera Logo
35 people viewed this question
Top Fuji Digital Cameras Experts
Richard Roberts
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
