Question about Hyundai ImageQuest V995 19" CRT Monitor
Brightness adjustment I was trying to adjust the brightness of the moniter display for an e-card, and now I can't see the screeen hardly at all, and I can't see the choices when I press the menu button on the bottom of the monitor....how can I adjust the brightness back to original? I tried unplugging monitor but the settings stayed the same. Please help! It's my dad's computer and now he can't play his computer games...he's pissed! thanks, debbie
I just buy a new dell inspiron 15r,but sometimes it's screen turns very bright so we hardly read anything or see the picture ,what could be the problem?
on the front of your moniter there should be some buttons one is for bright and one is for darker its the contrast adjustment.
Oct 16, 2010 | Computers & Internet
Monitor Brightness problem
it is still on warranty... check on service ... or you can try to download drivers .. or new chipset for your laptop..
or on startup hit f and chose last known good configuration thaht worked.
Dec 02, 2009 | Computers & Internet
Hi! I am using a compaq presario 2500 laptop! My onboard keys are not functional ,so I have . purchased an ext. keyboard! there are no functional key on this keyboard. Can u help me as to how to adjust the...
XP: right click on desktop - properties
click on screen saver tab and click on power button
VISTA
Go to control panel, adjust used mobility settings, then adjust screen brighness
Jul 15, 2009 | Microsoft Computers & Internet
Dell moniter, brightness adjustment keeps coming on
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Jun 06, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
OPEN A BACK COVER ON MONITER
hi im josh try this solutions of mine. Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
WARNING: THIS IS A DANGEROUS PROCEDURE!!!
- Open the monitor casing and loosen the clamp holding he coils around he picture tube. You can loosen them (usually there’s a wing nut) and a rotate the coil assembly until the picture strengthens.
good luck please vote
Mar 06, 2009 | SAMTRON 55V 15" CRT Monitor
Moniter brightness
Have you tried using the manual controls on the keyboard for changing the brightness (Fn right arrow)?
I think the epower management is crap, usually I just uninstall them all and adjust things manually.
Jan 12, 2008 | Acer Aspire 5100 Notebook
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Hyundai ImageQuest V995 19" CRT Monitor Logo
57 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
