Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE TV Model D52GW12
TV will not turn on. When you hit the power button, it lights up three times and then turns off.
  • Debra Vitale Nov 30, 2008
    I unplugged the TV for 3 hours... plugged it back in and it still does not turn on. Is there anything else I can do?
    vitaleshop@att.net
    Sergeant:
  • 217 Answers
This type of problem normally happens due to internal problem in the capacitors .and the board needs to be checked for that to remove the faulty capacitors and replace it with new one.so just get it replaced as if u try to turn it on in this condition it will do further damage to the board as it is short from somewhere.
Posted on Nov 30, 2008
  • 103 Answers
Try unplug your TV for a few hours then plug back in and see if your problem gets solved. If not It could mean that you have a slightly more serious problem inside your TV usually its capacitors get faulty. You might need someone to come over and repair your unit.
Posted on Nov 28, 2008
  • 10,594 Answers
TV seems have problem in deflection circuit like horizontal output transistor short or fly-back transformer short.
If you know electronics and have experience of TV repair then you need service manual of this model to rectify problem.
If you don't have experience then I would recommend to call TV tech person.
Thank you.
  • GE Master
  • 19,396 Answers
Modern TVs have an inside device calld protection circuit.
When an internal error , like for example a bbad voltage, a short, or a defective component (IC , capacitors etc.), is being detected, the TV protection circuit will start an automated switch that turns the TV on standby to prevent further damage.
Sometimes the internal safety switch is just jammed because hit detected an incorrect value.
In this case you can fix the problem and wake up your TV draining power from TV completely, by leaving the power cord unplugged for a while.
Try first unplugging and waiting ten or twenty minutes.
If that does not work try leaving the cord unplugged for a longer times, let say two to three hours, to drain power completely and get rid of electrostatic charges on internal circuits.
  • Ginko
    Ginko Nov 30, 2008
    If hard reset (unplugging) did not fix the problem, that means that the tv must be inspected by a technician.
    When GE TV flashes three times, that means that there is a problem with the flyback transformer, the technician need to check the soldering joints at the fyback transformer , or to replace the flyback.
    Call the number listed on the user manual to get a qote for a repair. If TV is less than 5 years old, ask also price and modalities for an eventual warranty extension.
    This is often cheaper than a single repair and will cover repair expenses for one extra year.
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
My GE D52GW12 52 in TV only turns on after I push the power button numerous times (sometimes up to an hour). The green light on the power button comes on but kicks off after about 5-10 seconds. It is...
Thats a very easy repair which is almost always related to failed power capacitors CP150, CP120 and CP114. You can get the RCA repair kit which is the same as the GE from www.tvrepairworld.com the kit is called the ATC221 CP150, CP120 & CP114 repair kit . The kit contains the caps and the CD with instructions for the repair.
Apr 30, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have 2004 GE 52' Projection TV and it won't turn on. All it does is the power button lights up three times and it makes a flick sound and it never shows turns on or shows anything. How can I fix this?
I have the same issue! Did you ever find anything out on yours? Any information would be great! I would hate to throw the TV away because when it's on it works great!
Thanks
Alexis
Dec 21, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Push power button lights and goes out three times then stays off Will come on after two or three cycles of button pushing
Replace the three Capacitors CP150, CP120 and CP114 very common problem for that model You can get that RCA repair kit from www.tvrepairworld.com RCA and GE are the same TV.
Sep 22, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Broken GE HDTV - Need Help To Fix
The deflection board needs replacement. The chirping is indicating the deflection circuit has an issue. You can get a replacement deflection board from www.tvrepairworld.com which includes instructions on how to remove and replace the board.
May 26, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE Tv, replaced flyback... still nothing.
Have you ck 3 capacitors on deflection board cp150 2200uf 16v, if it is bad other 2 caps are 220uf 35v cp114 cp120 Your TV is really a RCA
Sep 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
