Question about American Range AR-6-C Gas Kitchen Range
THE PILOT IS ON BUT THE OVEN WILL NOT COME ON
AMERICAN RANGE AR-6-C
  • 734 Answers
Igniter that heats up to light the oven may have gone bad. if it has it will not allow the gas to come on in the oven as a safety feature. Also a bad thermocouple in the oven can stop the oven from lighting.
When you turn on the oven do you see the igniter near the main burner come on? It will glow really red-orange and be bright. If on but dim replace it. If it does I would replace the thermocouple in the oven itself. Usually looks like a rod in clips on the back wall of the oven with a metal wire leading through to the back or bottom of the oven. A hardware store should have a replacement for it so pop it out of the clips and undo the other end then take it with you to match up.
Posted on Nov 28, 2008
    Sergeant:
  • 291 Answers
Check out if the ignitor is glowing or not.
  • 1 more comment
  • jamesrated Nov 28, 2008
    Understanding Gas Oven Ignition Systems
    Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
    There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models .
    http://www.appliance411.com/faq/gas_rang...
    Ignitor glowing but oven only gets warm
    If the ignitor ages and gets 'weak', it is possible for it to glow and generate some warmth in the oven but the oven burner never actually come on to get the oven up to proper temperature. It is also possible for the oven burner to light and heat once but never cycle back on again afterward. The heat generated by the ignitor may keep the oven warm for a while until it is noticed that the oven isn't heating 'right' any longer.
    Oven not heating and ignitor NOT glowing
    Power must flow from the control system to the ignitor and through the oven valve. If there is any break in that circuit, the ignitor will not glow and thus the gas valve not open. The ignitor not glowing could be caused by the ignitor or the gas valve being open (infinite resistance - no continuity). If both have continuity (ie. at least some resistance) and the ignitor is still not glowing, a problem in the control system or the rest of the electrical circuit would need to be investigated.
    An ignitor and oven valve having continuity does not necessarily that they are good, just that they're not electrically open, which is only one way that they might fail. If either has NO continuity at all (ie. infinite resistance) they are likely defective and need to be replaced.
    gnitors do age and will eventually generate less heat than they normally should. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this occurs, gas released into the oven can result in a gas smell or sometimes even build up to the point where when finally ignited, the extra amount of gas lit can cause a small explosion inside the oven.
    In the latter case, the oven should be removed from use until the condition can be looked into and corrected. DO NOT continue to use a gas appliance in such a condition!
    Pulsating Oven Flame
    It can sometimes happen that the ignitor is just on the verge of allowing the correct amperage to the oven valve, but not quite. In such a case the oven valve can repeatedly cycle open and close quickly, creating an 'pulsating' burner flame. Testing for proper amperage draw of the ignition circuit is needed to determine if a 'weak' oven ignitor may be responsible instead of an internal problem with the oven valve itself.
    Observations/tests necessary to diagnose problems
    Does the ignitor glow when the oven burner should be heating?
    If NOT glowing at all:
    Does the oven ignitor have continuity?
    Does the oven valve have continuity?
    Is the oven control system providing power to the oven components?
    If the ignitor IS glowing:
    What is the amperage draw* on the ignition circuit?
      *There is NO voltage or resistance test that will help to diagnose the cause of the problem at this point. Only an amperage test is relevant. An ignitor with a white or beige colored rectangular base should draw 3.2 to 3.6 amps. A round base or powder-blue colored rectangular base ignitor should draw 2.5 to 3.0 amps.
    Genius:
  • 1,142 Answers
Please specify your question?
  • Maanita Chadha
    Maanita Chadha Nov 28, 2008
    If your range/oven doesn't seem to work at all, check these:
    Fuse/circuit breaker
    Main wiring
    Range/oven wiring
    Check
    to see if power is getting to the range/oven. Does anything turn
    on--even a light? If not, check for a blown fuse or tripped circuit
    breaker.
    Main wiring
    Often
    the main wiring connection from the house, at the range/oven, gets
    burned and so breaks the connection. Then you may have to replace the
    power cord to the range/oven, and the terminal block that the wire is
    attached to.
    Range/oven wiring
    There
    may be a broken or burned wire at the back of the range/oven. If you
    repair any of the wires, use only proper appliance-grade wire and wire
    connectors.
Hi,I have american range, my oven pilot light wont stay lit.
The most common cause for millivolt pilot light systems not staying lit is a bad thermocouple.
Jun 11, 2016 | American Range Kitchen Ranges
I have an American range ARR-366IS and the oven will not heat.
I do not know this gas range but I would venture to say the pilot light is out (may not have one as it is labeled green) or the igniters have failed.
Dec 06, 2014 | Kitchen Ranges
American Range AR-6 Oven is not turning off
the oven control thermostat is not closing when you turn it off . it has to be replaced.be sure to turn off the gas first.
Dec 03, 2013 | American Range AR-6 36in Commercial 6...
I have an american range gas convection oven i think lightning may have struck them but they still run but the gas will not come on the igniter just keeps ticking and no gas
there posible pilot burner is clogged, you may want take off the gas pilot tube and make a quick turn on to see gas is come out from pilot tube or disconnect from gas valve pilot connector...have fun....
Sep 23, 2011 | American Range Ovens
The pilotlight has flame but the oven does not start(no flame ).ARW36-6
Hello Hughdrolle,
I understand that you are having a problem with you American Range ARW36-6. The problem that you are having is that the oven pilot is burning, however, the oven burners will not light. This is a common problem that is caused by the thermocouple.
I understand that you state that the pilot is running. You should check to see if the pilot's flame is heating up the thermocouple. This should be a little cooper tube/wire that runs from the gas valve down to the pilot. If the flame from the pilot is not heating the thermocouple enough the gas valve will not receive the signal to turn on and the burners will not energize.
However, if the pilot is hitting the thermocouple then you will need to replace it. Most of the time you only need a screw driver and a small wrench to remove the thermocouple. You will want to remove it from the gas valve first then from the pilot. Make sure that you turn off the gas/pilot and allow the thermocouple to cool before you try and change it. Also make sure to line up the new thermocouple as not to cross thread the thermocouple and gas valve when reinstalling.
You can pick up a replacement thermocouple from any local hardware store they are not very expensive to purchase. Pay attention to the length as they come in many different lengths to accommodate many different gas appliances.
Thank you for choosing FixYa.com if you have any further questions please post back to this thread and I will try to assist you.
Justin
Apr 15, 2011 | American Range ARW36-6 Stainless Steel...
The gas for the oven will not go on when the knob is turned and there is no gas to keep the pilot light for the oven on.
The ADJ 30 doesn't have an oven. There are 5 top burners and an adjustable underbroiler. The underbroiler used the heat from the top burners to heat the underbroiler. Is it possible that the broiler is sitting on top of some kind of oven?
Sep 08, 2010 | American Range ADJ-30 Gas Kitchen Range
Pilot won't lite.
replace electrode and make sure their is a gap of 3mm from electrode to burner and replace ignition lead from d.s.i box also find ignition box and look at it as you start the oven (in the dark) if you see blue sparks replace it
Apr 22, 2010 | American Range AR-4B-24G Gas Kitchen Range
DCS commercial range #36-6-1L running propane. 6 burner tops light fine, but the oven has just stopped lighting after 7 years. When I try to relight the pilot light (depress red button, click cliker) it...
You might need a new thermocouple. The thermocouple tells the oven that the pilot is lit and that it is ok to let gas into the oven. It is the metal rod that is connected to the pilot. They are fairly cheap and easy to install.
Jul 06, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
American Range AR-6-C Gas Kitchen Range Logo
52 people viewed this question
Top American Range Kitchen Ranges Experts
Craig Butler
Craig Butler
Oliasys
Level 1 Expert
Are you an American Range Kitchen Range Expert? Answer questions, earn points and help others
