Question about Panasonic TH-42PX60U Television
Panasonic TH-42PX60U HDMI stopped working
I unplugged the HDMI and plugged it back in while the tv was running. Now the port no longer works. Is there anything that can be done for it? Can something be reset for instance? Or is it that I have most likely fried my port?
  • 10,594 Answers
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
Posted on Nov 28, 2008
I have Panasonic th42 plasma.i m playing xbox360 for a year on hdmi port 1 .but 1 day when I turn on my TV than my Xbox the screen is showing black than change the port to 2 than port to 3 same problem not...
It sounds like you did some good testing by taking your xbox to a friend's home and trying it with his TV and HDMI input. You can try a reset on your Panasonic TV and see if that restores the HDMI input functions. Note this will erase your programmed TV channels so you'd need to re-enter those.
  1. Unplug the TV for at least 15 minutes
  2. Plug it back in and you'll be prompted to go through the initial setup just like when the TV was new.
If after that you still have no HDMI function on any of the inputs, that would indicate the set needs some service by a technician.
Good luck.
Mar 21, 2015 | Panasonic Televison & Video
Why are the HDMI ports on PN58C7000YFXZA are no longer working?
Try unplugging the cables and plugging them back in at both ends -- HDMI cables sometimes lose contact after a while. This is especially true if the wires are not supported close to the plug -- they can pull loose.
Another possibility: reset the TV to restore functionality. Simply unplug it from the power, wait a minute, and plug it back in.
If that doesn't solve the problem, the circuit board may have failed. Your set is a refurbished model, and it's possible that this is a recurring problem.
Jun 08, 2014 | Samsung PN58C7000YFXZA 58IN PLASMA HDTV...
Sylvania hdmi port not working
Sounds like you may need a new main board.
Jan 27, 2018 | Sylvania LC320SSX 32 in. LCD TV
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My Philips 42PFL5332D has quit playing my Sony Blu Ray player (model BDV-T10) it was working fine, I finished watching one movie went to put in another and it wouldn't work. Thought it was the Sony,...
Tv still working,with the incomming broadcating tv signal cable plug in,working is fine wright?Tries tv unplug,replug the tv back like an hour later.Let the tv resetting itself back to the factory setting.Go into the tv Menu goto PICTURE,go down to reset the tv Tuner signal board,that to reset the whole entire Tuner signal board back to factory setting,now all the incomming plug&play like the HDMI ports on tv,should work now.Not,than i can't tell what happen to the tv exept the tv Tuner signal board have problems,that it.
Oct 26, 2010 | Philips 42PFL5332D 42 in. LCD Television
HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
Jun 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection....
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
May 11, 2009 | Vizio L37 Television
HDMI no longer working
JVC AV-48P575 HDMI reset procedure:
1. Unplug HDMI cable from tv.
2. Unplug the tv.
3. Remove the rear (low) back cover.
4. Find the 6 pins on the board of the HDMI module and shortcut the pins no.1 and no.2 using a jumper(i use an old hard drive jumper).That's the higher to pins if you can't see the number.
5. Put back the rear cover.
6. Plug the tv.
7. Turn on the tv.
8. Unplug the tv(without tunrning it off).
9. Remove the back cover.
10. Remove the jumper on the pins 1 and 2.
11. Put back the rear cover.
12. Plug the tv and you're done.
Jan 04, 2008 | JVC AV-48P575 48" Rear Projection...
Panasonic TH-42PX60U Television Logo
2,432 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
